Author Topic: arcade vga  (Read 1832 times)
alienware32
  • Last login:September 26, 2009, 05:28:40 pm
arcade vga
« on: February 12, 2007, 08:48:31 pm »
can a arcade VGA card 25inch cga monitor video amp work will the card do the low resolution after install the drivers
northerngames
  • Trade Count: (+18)
Re: arcade vga
« Reply #1 on: February 14, 2007, 05:11:12 pm »
not sure what you mean but:
arcadeVGA output's 15khz + 15khz standard standard arcade monitor = nice native display at 15khz if you have a med. res 25khz a trident blade pc card maybe the better for the 25khz med. res. type. the arcadeVGA kinda support's the 25khz but not as good as the 15khz that they were origanaly made for.
alienware32
Re: arcade vga
« Reply #2 on: February 14, 2007, 06:50:32 pm »
what i mean will those three thing work  the card the amp and a standard cga monitor because i dont need the tri monitor
JMB
  • Last login:July 20, 2023, 07:29:22 pm
Re: arcade vga
« Reply #3 on: February 21, 2007, 03:02:36 pm »
Depending on your monitor type you may not need the amp.  My 25" WG works fine directly from the AVGA.
alienware32
Re: arcade vga
« Reply #4 on: February 21, 2007, 10:07:34 pm »
thanks for the info :)
northerngames
Re: arcade vga
« Reply #5 on: February 27, 2007, 04:42:28 pm »
yeah the wells and hentrix or whatever there called do not need the video amp all you would need is the monitor the arcadevga and a vga break-out to keep it clean,
