Author Topic: Routing recess for trackball mount  (Read 4155 times)
superclive
  • Last login:September 07, 2008, 03:46:17 pm
« on: February 06, 2007, 02:50:45 am »
Hey all,
     Firstly apologies if this question has been answered elsewhere, I've searched the forum but can't find anything.
I want to use my router to recess the trackball mounting plate into the control panel. Problem is I'm not sure how to do this. I bought a router for this project, used a slot cutter to cut the T-molding grooves and haven't used it since - so don't really know much about it. All the bits I have seen for routers are appropriate for cutting narrow grooves - so what is the best way to go about cutting a 6" square recess?
Thanks in advance for any answers.
acevedor2
  • Last login:May 25, 2024, 08:21:24 pm
Re: Routing recess for trackball mount
« Reply #1 on: February 06, 2007, 06:29:24 am »
Make a jig.  Then you can use a template bit to recess the mount.  You make the jig just like you would to recess a joystick.
Dedicated - Working:
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Pool Sharks - Pinball
Projects:
Pole Position
Pole Position 2
rcrules
  • Last login:February 28, 2026, 10:30:00 am
« Reply #2 on: February 06, 2007, 09:39:52 am »
I used the principals of Timoe's tutorial at...
http://forum.arcadecontrols.com/index.php?topic=51235.0
Here is a picture of my control panel with the "jig" attached...
http://forum.arcadecontrols.com/index.php?topic=59345.msg612911#msg612911
(I should have used wider scraps on the left and right sides of the "jig")
superclive
« Reply #3 on: February 06, 2007, 11:39:46 am »
Thanks Gents. Given my non-existent woodworking skills it would have taken me until hell froze over to work that out for myself.
Cheers!
