Author Topic: Monitor behaving weird  (Read 2613 times)
dmbfan
  • Last login:February 22, 2007, 07:17:07 am
« on: February 04, 2007, 04:24:41 pm »
I have a multisync arcade monitor using the new PCI-E arcadevga2 video card and am experiencing wierd behavior after about 5 minutes of use.  I don't know if its the monitor or video card.
Its very hard for me to explain.  The best way I could describe it is the colors start losing their vividness.  Almost like its cycling thru different hues of colors.  There is like a yellowish hue that is cast over the whole screen and flickers a little.
What the heck is going on?  Resolution set at 800x600 @ 56 hertz.
« Last Edit: February 05, 2007, 08:24:40 am by Peale »
grantspain
  • Last login:Today at 05:48:12 am
Re: Monitor behaving wierd
« Reply #1 on: February 05, 2007, 07:07:25 am »
always worth trying a different vga cable with this type of fault
dmbfan
Re: Monitor behaving weird
« Reply #2 on: February 05, 2007, 04:34:37 pm »
How would I go about doing that as the cable is attached to the monitor?  I assume its easy to replace then.
SirPeale
  • Green Mountain Man
« Reply #3 on: February 05, 2007, 04:37:24 pm »
Ah, one of those.  No, it's not particularly easy.
With it on, *gently* manipulate the connector where it is hooked to your VGA card.  Note what happens on screen.  Does it change?
dmbfan
« Reply #4 on: February 05, 2007, 05:26:56 pm »
Yeah.. actually when i unplug it it goes away for a little while but comes back.
dmbfan
« Reply #5 on: February 19, 2007, 09:16:04 pm »
bump.  i need help!
grantspain
« Reply #6 on: February 20, 2007, 03:13:21 am »
have you tested it with a different graphics card and without the cable plugged in
