Author Topic: i need help with my HAPP vision pro 27"  (Read 1958 times)
draginit
  • Last login:December 26, 2023, 12:59:18 pm
« on: February 02, 2007, 08:55:15 pm »
i recently got my monitor back from repair for no picture on a new monitor issue,...but it appears they didnt tighten down the tuning rings on the neck, so i imagine the travel back caused them all to fall even. my problem now tho is two things---
-one, the overall picture has a purple haze to it, there is no true black because it looks like their is too much purple, and  its more noticable with white images
-two, the image is extremely large and using the on-screen controls cant fit to screen, it says "min" on the horizontal size icon and the image is cutoff on the left or right depending on h position. - the start menu is cutoff
!?!?-is this due to the tuning rings or something else.  all but two rings are laying flat. i know it wasnt like that when i sent it to them. the monitor has less than one hour of on-time, so im frustrated with HAPP as this is the third attempt to resolve the issues and is getting costly.
-any outside help would be greatly appreciated, ive been without my machine for months now
« Last Edit: February 03, 2007, 02:03:46 am by draginit »
Ken Layton
  • Guru
  • Technician
Re: i need help with my HAPP vision pro 27"
« Reply #1 on: February 04, 2007, 12:49:52 pm »
The "Vision Pro" models are actually made by Tovis (www.tovism.com).
draginit
« Reply #2 on: February 06, 2007, 06:13:47 am »
ken, thanks for showing me that website, after translating it tho i couldnt find the information i was looking for,, however it did lead me to find info on the rings on the neck and by doing so i was able to cure the purple haze and learn a thing or two about what they do, fortunatly for me after i learned the possibliy of there being a factory felt line i was able to line them back up....but it didnt fix the images size....is this convergance?? and is this something that i would only make worse if started messing with?,  i was able to find some inormation on convergance on the net but it didnt seem to coincide with the rings...could you point me in the right direction maybe as i continue to research? thanks for any help..
