Author Topic: Marquee Light , can I get it to automatically turn on when I power Up The PC?  (Read 1474 times)
mrclean
    • Guscade
Is there any way to get my Marquee Light to turn on automatically when I power up my PC ? Instead of manually doing it. & Shut Off automatically on "shutdown"?
2,370,650 Gun.Smoke
TOK
  • The Game Always Wins
Sure, there is a project called the Bits Ltd. Smart Strip. Anything plugged into it will be powered when the PC is powered up. I'm using one of those with great results.
I also found something similar but not as fancy at Sears. Its meant to turn on a light, etc when you power up a piece of equipment. That was $24, and also works great.
mrclean
    • Guscade
Sounds good.. but I already have a battery back up, is it safe for me to use both?? plug one into the other kinda thing or is that just asking for a fire hazard
2,370,650 Gun.Smoke
ahofle
    • Arcade Ambience Project
Battery backup of what?  The marquee light?  I'd ditch the batteries and plug it into the Smart Strip outlet as a slave device.
« Last Edit: January 15, 2007, 02:11:37 am by ahofle »
Naru
  • Last login:June 29, 2007, 12:01:34 am
Sounds like you have your lighting finished already,
so this may be of no use whatsoever.
Cold Cathode RetroFit Lighting Kits
http://www.happcontrols.com/lighting/95263000.htm
These lights come with a hard drive connector so
you can attach it to your PC power supply.
It would then turn on/off along with your computer.
I purchased one, and it's certainly bright enough.
However you will most likely have to add some length
to the wires.
« Last Edit: January 15, 2007, 02:14:10 am by Naru »
whammoed
  • Last login:April 17, 2026, 12:27:07 pm
  • Crack don't smoke itself
    • NiceMite
this can be done easily with a relay also.
I have a product available if you don't want to wire your own:
http://www.nicemite.com/PowermiteDD/PowermiteDD.htm
check out the example video
needlesmcgirk
  • Last login:September 15, 2009, 10:54:31 pm
Can't you just leave the power on the light on, and have everything plugged into a powerstrip, and just turn the power on the powerstrip?
SithMaster
yes thats how mine is setup.
PileDriver
  • Last login:May 28, 2025, 08:53:44 am
  • I want to built my own arcade!
I just wanted to second  the powermiteDD solution, Great product!
