Author Topic: Vertical light grey bars?  (Read 1554 times)
Bobbler
  • Last login:July 15, 2016, 11:33:30 am
« on: December 05, 2006, 12:45:40 pm »
Well today I got my ArcadeVGA so have been doing some playing on the monitor in the cab. One thing I have noticed is that there is sort of patchy grey vertical bars on the screen at any resolution. They persist when I remove the video cable.
I can sorta combat it by turning the brightness down but then I find some games with dark areas are a bit hard to see (especially when you add the tinted glass into the mix too!)
Do any of you guys recognise the symptom at all?
grantspain
Re: Vertical light grey bars?
« Reply #1 on: December 05, 2006, 03:39:51 pm »
some sort of chassis ground problem or caps if its jailbars
Bobbler
« Reply #2 on: December 05, 2006, 03:58:46 pm »
Will have to double check the grounding as I removed a lot of (rather tattered) the original wiring when I did my conversion. I am hoping I just need to add a ground feed to the chassis to the ground of my power feed.
Caps is not really something I want to mess with because of the need to discharge the monitor. Just dont see the point in risking it when a replacement monitor is only a little more than the amount of a cap kit and the time to do it.
Thanks grantspain
hammad
  • Last login:August 14, 2011, 04:23:27 am
« Reply #3 on: December 09, 2006, 04:50:49 am »
This problem is because of your flyback so you should get it checked.
