Author Topic: ***Driving Equipment for Xbox360, PlayStation3, PS2 and PC***FORCE FEEDBACK  (Read 17918 times)
NiteWalker
  • Last login:April 25, 2022, 07:33:24 pm
  • Routers can do anything.
    • SimpleCase Custom Arcade Stick Enclosures
Nice job Tim. Looks really pro.
It's 9am. I'm calling it a nite.
GoPodular.com
  • Last login:April 23, 2008, 10:09:55 pm
    • GOPODULAR!
All work, no play.   :dizzy:
email sent.
Great job btw Timoe, I've been wanting to build one for myself but just haven't had any time.
theCoder
So I think I finally get it.  These are intended to be table top components, sitting at a desk, facing a TV or monitor.  I really wish I could justify the money for such a nice wheel and pedal assembly.  Great job.
<edit>   I went back to the front page, and now remember that this gear is going into an off-the-shelf driving frame.  Doh...
wintord
  • Newbie
  • Last login:May 15, 2007, 12:03:33 am
Thanks to the help in this thread I have modified my wheel to use external sequential shifter and hand break by wiring the shifter to the two push buttons on the paddles and the handbreak to the back of the pcb. There is a connector on the side panel of the wheel so i can unplug them when not needed.
Now when they are unpluged the wheel works fine, but when i connect the handbreak and gears they work fine but the up on the d pad registers as down so have no way to go up in the menu, does anyone know what may be causing it spent hours trying to work it out but cannot seem to find a solution thanks for any help you can give
