Author Topic: neotec 2702  (Read 2672 times)
worm
  • Last login:April 17, 2013, 10:45:31 pm
neotec 2702
« on: October 10, 2006, 10:09:30 pm »
 I am wirking on a 2702 neotec it power up and everything , but I hear a sound like high freq it won't syn can control horz hold.
What do I do?
I am alway willing to learn, so please share the knowledge.
Ken Layton
  • Guru
  • Technician
Re: neotec 2702
« Reply #1 on: October 10, 2006, 11:42:53 pm »
Has this monitor been cap-kitted yet?
worm
Re: neotec 2702
« Reply #2 on: October 11, 2006, 02:36:51 pm »
Yes it has even on the neck board.
Ken Layton
  • Guru
  • Technician
Re: neotec 2702
« Reply #3 on: October 11, 2006, 06:01:54 pm »
The flyback probably has hairline cracks or maybe pinholes in it. The flyback fail alot on this series.
grantspain
Re: neotec 2702
« Reply #4 on: October 11, 2006, 06:15:08 pm »
try turning the screen volts up a little and report back on the outcome
worm
Re: neotec 2702
« Reply #5 on: October 12, 2006, 02:40:05 am »
everything is working fine except for it wont sinc could it be IC 201 or IC 401?
Ken Layton
  • Guru
  • Technician
Re: neotec 2702
« Reply #6 on: October 12, 2006, 03:05:19 am »
I've only worked on a 2701 model which is an EGA resolution.
Is your sync wires connected properly and of the right polarity. The 2701 I worked on only accepts composite negative sync.
grantspain
Re: neotec 2702
« Reply #7 on: October 12, 2006, 05:26:15 am »
i am pretty sure thats the same monitor that i worked on in a artic thunder a few months ago,its a 25khz yes?
can you tell me the set up you have
did this monitor just go like this or have you installed a different game or changed anything?
Ken Layton
  • Guru
  • Technician
Re: neotec 2702
« Reply #8 on: October 12, 2006, 10:09:12 am »
Here's some basic monitor information on this series:
2700 Standard (cga, 15.75 khz) resolution
2701 Medium (ega, 25 khz) resolution
2702 VGA resolution
grantspain
Re: neotec 2702
« Reply #9 on: October 12, 2006, 10:57:48 am »
i am sure the neotec xxx2 range are denoted by the prefixes and suffixes e.g nt2502e is a 25 inch ega and nt2502c is a 25 inch cga-i could be wrong its just thats what my neotec nt2502e manual said
Ken Layton
  • Guru
  • Technician
Re: neotec 2702
« Reply #10 on: October 12, 2006, 11:42:17 am »
Nope this series is exactly what I quoted and it's in the manual that way too. The 2702 is VGA
