Author Topic: dvi to component tv adapter problems  (Read 1676 times)
ultravorx
  • Last login:May 09, 2007, 05:59:38 pm
« on: September 23, 2006, 03:48:07 pm »
hi guys, i finally decided to purchase the ati dvi to component adapter for my set.  my  only problem it doesnt work right.
i have a radeon 9700 pro agp card running win xp pro with a p4 3.0ghz processor with 1gb ram.
the problem i have is that it never want to show up on my tv.  i have a 27" insignia with component input.  i have switched the jumpers on the adapter to 480i and 480p.  but when the tv eventually loads, its too big for the screen.  the res says its a 640x480 but it looks as its overanning.   i cant fix it eithe.  it also says that its running at 30hz which i cannot adjust.
wheb running mame32, it only shows a portion of the screen due to overscan.
any help would be greatly appreciated.
frank
ddw
  • Last login:June 21, 2020, 05:54:12 am
Re: dvi to component tv adapter problems
« Reply #1 on: September 24, 2006, 09:18:09 am »
I set my computer up with dvi to component had the same problem I made sure only the the 480i button was set and then set my tv to main desplay and the overscanning problem was gone. as secondary it overscaned at lest 50%
Hope that helps ddw
ultravorx
« Reply #2 on: September 25, 2006, 04:27:09 pm »
i tried just the one jumper, and i still dosnt work.  when windows boots the screen flickers blue, then goes back to black stating no signal.
even when i set the tv to primary display it dont work.  plus my vga goes off, and i have to go to safemode to reset the video.
this really sux!
frank
richms
  • Last login:January 07, 2025, 06:42:57 pm
  • s92a sucks
    • richms.com
« Reply #3 on: September 26, 2006, 07:15:35 pm »
It will always overscan since that is how TVs operate, you dont have a black border when watching tv or a dvd.
Either get the service info for the tv (good luck on a house brand) to pull the image in, or make a lower res mode in powerstrip with the same clocks but less resolution so that you get a smaller image in the middle of the screen.
Otherwise if you can, try 576i, which is a pal mode and only 50 hz, this may let you see more of windows when you are in the UI, and the overscan will be correct(ish) once you launch a mame game at an arcade resolution
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #4 on: September 27, 2006, 05:36:18 am »
If the screen is going black it does not like something about the component signal it's getting.
I have not used the ATI dongle, but I know on some DVI->component adapters they will only work if you set the desktop resolution to one the TV will expect - which is extremely limited e.g. 720x480i or 720x480p.
In the ATI control settings/control center there should be options for this I am sure...
ddw
« Reply #5 on: September 27, 2006, 07:00:28 am »
Go to the main forum in bookmarks of interest their is a section about TV and componet I think 6 pages Iamb very happy with my setup running Mame at 640x480 TV set at 640x432 windows 640x480 don't use window much  can always plug into a PC monitor if I need to spend more time with windows .good luck
ddw :)
