Author Topic: Help with FCE Ultra "its too fast!" ? running a bit too fast  (Read 4201 times)
mrclean
    • Guscade
« on: September 23, 2006, 03:24:34 pm »
Help with FCE Ultra "its too fast!" ? running a bit too fast any way to slow this down ?
2,370,650 Gun.Smoke
jelwell
  • Last login:December 24, 2014, 03:47:21 pm
Re: Help with FCE Ultra "its too fast!" ? running a bit too fast
« Reply #1 on: September 23, 2006, 10:36:21 pm »
I've had all sorts of, minor, problems with FCEUltra. I highly suggest VirtuaNES.
Joseph Elwell.
gonzo90017
« Reply #2 on: September 24, 2006, 12:21:30 am »
Try changing the sync method. Config>Method
mrclean
    • Guscade
« Reply #3 on: September 24, 2006, 01:45:42 pm »
Joseph Elwell.
Hey that seems to be way better! however withing the emulator im getting an error message on various roms.. ":Because a NES Header is illegal, there can be the thing that cannot work normally, do execute?" ? can i bypass this error ?? its annoying just on some games will it do this
I might start a new thread about this but hopefully someone can fix it here first
2,370,650 Gun.Smoke
jelwell
« Reply #4 on: September 25, 2006, 06:39:56 pm »
Joseph Elwell.
This is a "feature". From the wiki, which I wrote ;) :
"VirtuaNES is stricter with ROM (headers) checking than FCE Ultra which means instead of bizarre behavior, VirtuaNES will not allow bad ROMS to be used."
Most Emulators don't complain, because the headers aren't needed for emulation. HOWEVER, they can be sign that the entire rom is corrupted if your header is bad.
I suggest getting clrmamepro and/or goodtools and checking your roms. On the bright side, you're likely to have a whole lot fewer problems, but until you get good roms you'll see a few of these messages.
The source for VirtuaNES is available, so if you can't get all your roms perfect you could comment out that warning if you just don't want to see it anymore. There might be a flag you can pass but I didn't notice one and I've only ever gotten this message once.
Joseph Elwell.
mrclean
    • Guscade
« Reply #5 on: September 26, 2006, 05:34:11 pm »
Basically I used goodtools to eliminate all non-usa roms etc.. I was tired of seeing a list of like 8,543 and only playing a few of these games and after having my friends say uhh do i pick the E one ? the UE the a1, b2, beta, prot,Hack The Tgs version etc.. etc.. so on and so on.. so at the end of the day I was left with about 655 USA Roms and of those only about 30 had this header error in VirtuaNes So I hand tested all 655 individually which was tidious to say the least.. plucked and replaced all of the header error ones. The one other thing I guess I cant complain too much about it but when i Escape VirtuaNes with the ESC key to go back to the mamewah list VirtuaNES sometimes displays the gui menu ontop where as sometimes itll exit with one ESC button push instead of two. Just a slight annoyance.. but happy that its 98% the way I want it.  :dizzy:
2,370,650 Gun.Smoke
