Author Topic: Monitor issues with ArcadeVGA, J-Pac and Xp  (Read 2312 times)
dirk
  • Last login:October 03, 2013, 03:56:13 pm
« on: September 22, 2006, 10:59:21 am »
Hi everyone,
I've got an ArcadeVGA in my PC which is then linked to a J-Pac (which the arcade machine is plugged into.)
I've installed the drivers but something is wrong. The picture quality isn't great, it is 'wavy' in loads of places:
Occasionally the bottom of the screen appears at the top:
MAME games are almost unplayable:
The monitor was fine when I bought it and the bloke plugged a JAMMA game in. What have I done wrong? (I know nothing about any of this!)
Thanks in advance!
SirPeale
  • Green Mountain Man
Re: Monitor issues with ArcadeVGA, J-Pac and Xp
« Reply #1 on: September 22, 2006, 07:45:23 pm »
Almost looks like a sync issue, have you tried adjusting sync?
dirk
« Reply #2 on: September 23, 2006, 05:02:38 am »
No, how do I do that?
richms
  • Last login:January 07, 2025, 06:42:57 pm
  • s92a sucks
    • richms.com
« Reply #3 on: September 23, 2006, 06:06:12 am »
With the distortion changing with brightness of the lines its on, it could also be a grounding issue between the vidoe card and the monitor. check that is connected well and that its not trying to rely on the chassis ground for a video ground.
dirk
« Reply #4 on: September 23, 2006, 06:23:33 am »
Thanks. I'm totally new to this.
Do you mean check the video card in the PC or the J-Pac connection with the cabinet? Where's it best to put the J-Pac when it's connected?
grantspain
  • Last login:Today at 10:44:42 am
« Reply #5 on: September 23, 2006, 10:49:06 am »
looks like the wrong sinc signal
dirk
« Reply #6 on: September 23, 2006, 01:00:45 pm »
I'm really grateful for all your advice. How's best to check/alter the sync?
wildfire123
  • Last login:November 28, 2006, 02:07:21 am
« Reply #7 on: September 28, 2006, 12:42:22 am »
are you using both kb ports of the j-pac? this happen to me if im only using one of the ports in the j-pac.
dirk
« Reply #8 on: September 28, 2006, 06:30:26 am »
Yeah, one of the ports is connected to the PC's keyboard socket and the other has a keyboard plugged into it.
wildfire123
« Reply #9 on: September 28, 2006, 07:28:21 pm »
is ur jamma connector looking like this? where all the pins line up
