Author Topic: Which Mame32 Version?  (Read 1750 times)
sportswizdan
  • Last login:April 05, 2012, 02:13:39 am
« on: September 08, 2006, 11:16:32 pm »
     I need help from all you experts. I have Mame32 V.99 on my computer right now. I will be getting my cabinet next week some time. My little daughter loves the Flintstones memory match game which came out in version .102 something, so I will need to upgrade to at least that version of Mame. I am very new to setting up all of this emulation stuff, so I want to make sure everything runs as smooth as possible. What is the highest version of Mame32 I should upgrade to in your opinions? I was thinking V.104. I know that starting in version .105 you have to "map" the trackball and spinner (or is that pretty easy to set up?) Or Should I go with the newer .108? Your opinions will be greatly appreciated.
Thanks, Dan
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
Re: Which Mame32 Version?
« Reply #1 on: September 08, 2006, 11:20:36 pm »
There are 2 classes of mamers. those that upgrade and those that don't.
I say stick with the lowest version you can use that will run the games you want. It'll usually run faster and have less complications.
