Author Topic: How would I go about building something like this  (Read 1736 times)
Hoagie_one
  • Um....whats a cabinet
« on: August 31, 2006, 04:23:47 pm »
I need to devise a switch that will have two items plugged into it.  When the switch is off, I want it to cut all power to both items.  When I switch it on, I want it to power up the first item then wait 1 minute then power on teh second item.
Anyway to do this?
Re: How would I go about building something like this
« Reply #1 on: August 31, 2006, 04:33:55 pm »
Relay.
Hoagie_one
« Reply #2 on: August 31, 2006, 04:34:37 pm »
do theymake time delay relays?
Hoagie_one
« Reply #4 on: August 31, 2006, 04:44:50 pm »
moreover, can someone point me to a relay that would do what I need it to do?
« Reply #5 on: August 31, 2006, 04:54:14 pm »
Can't point you to a specific item without any info on the circuit you want to drop it into.
Here is a good list of time delay relays and spec sheets.
http://relays.tycoelectronics.com/time_delay.asp
« Reply #6 on: August 31, 2006, 04:57:21 pm »
just buying a timer switch might be better than a relay for a 1min delay. relays are usually for a few seconds of delay.
http://www.quasarelectronics.com/1020.htm
« Reply #7 on: August 31, 2006, 05:04:21 pm »
Quote from: Quasar
The board has a relay output
That's an adjustable relay.  The main difference is the range of adjustment as the adjustment is controlled outside of the relay itself.
SirPeale
  • Green Mountain Man
« Reply #8 on: August 31, 2006, 08:13:57 pm »
I'm curious...what is this project you're working on?
Glaine
  • Last login:April 24, 2013, 12:09:17 pm
« Reply #9 on: September 01, 2006, 10:12:59 am »
Sounds like what folks used to do with arcade monitors and PCs, I think PC-to-Jamma did this? Where you wait till the PC is loaded into the frontend program that has the resolution and frequency forced to arcade monitor readings and then turn on the monitor as the site said that feeding the arcade monitor the default 60hz etc was bad for it.
