Author Topic: 1 1/4" holes for Joysticks ...  (Read 1295 times)
Czapala
  • Last login:May 18, 2009, 11:04:35 am
« on: August 28, 2006, 03:38:01 pm »
I have read that you only need to drill 1 1/8" holes for (Happ) joysticks. (just like the buttons)
Is there anything wrong with 1 1/4"?
It will be in 3/4" MDF mounted from the bottom with slighty less than 1/4" routed from the bottom.  I was just thinking of more room for the stick.  But seeing as how I have not actually built one of these things yet, I guess I may be over thinking again.
.... then my daughter said "Daddy, those games are old."
ahofle
    • Arcade Ambience Project
Re: 1 1/4" holes for Joysticks ...
« Reply #1 on: August 28, 2006, 03:40:28 pm »
I have 1 1/4" holes.  Works perfectly for me, no rubbing.  And the dust washer completely covers the hole in all directions anyway.
bleemus
  • Last login:September 01, 2016, 12:53:24 pm
  • Party Pengo in the house.
« Reply #2 on: August 28, 2006, 04:10:13 pm »
1 1/8 was fine even for my P360 that was mounted slightly off center.  So just as long as the stick you are using doesn't have a really long throw, 1 1/8 will be just fine.
I agree with afhole though, 1 1/4 shouldn't hurt anything since the dust washer covers the whole shebang anyway.
Reality is overrated.
