Author Topic: Happ Vision Pro 27" and new Arcade VGA  (Read 1323 times)
mark6437
  • Last login:March 23, 2020, 03:20:11 pm
  • THB2
« on: August 25, 2006, 04:41:25 pm »
I emailed Andy on this but I figured I would get a faster response here. Will the ArcadeVGA work with this monitor? I read on one post when I did a search that it would not but it was a fairly old post and I was wondering if things had changed. I see there is a new ArcadeVGA out so maybe it has?
Thx
Mark
Hou TX
mark6437
  • THB2
Re: Happ Vision Pro 27" and new Arcade VGA
« Reply #1 on: August 25, 2006, 09:49:19 pm »
Ok I did some research and it looks like the Happ Vision Pro only supports :
Horizontal 30-40KHz
Vertical 50-120Hz
So I guess it will not work since the ArcadeVGA outputs 15khz?
I looked at some Wells Gardner monitors but I cannot figure out which is the best one. I need a monitor that will work with the Arcade VGA but can be plugged into a wall outlet and has the 15pin sub to plug into a video card.
Any suggestions? This Arcade Monitor stuff is new to me, been using regular PC monitors and TV's.
Thx
Mark
Hou TX
Negativecreep0
  • Last login:November 28, 2020, 10:59:49 am
« Reply #2 on: August 26, 2006, 11:48:48 am »
checkout billabs new 27" viewable 29" monitor              it does hi res as well as multisync
Czapala
  • Last login:May 18, 2009, 11:04:35 am
« Reply #3 on: August 28, 2006, 10:26:18 am »
Betson multi sync  27"  Check out the RetroBlast! review.
It is what I have and I use the AVGA as well.
.... then my daughter said "Daddy, those games are old."
