Author Topic: Applying Vinyl Sideart  (Read 2075 times)
greaser
  • Last login:December 21, 2007, 06:28:21 pm
« on: August 19, 2006, 03:53:04 pm »
I am still waiting for my sideart to arrive from classicarcadegrafix and I just noticed under the installation instructions that latex paint is NOT recommedned. Well i painted my cab with latex paint. Am I screwed? Will I still be able to apply the sideart?
koolmoecraig
    • My Intervention
Re: Applying Vinyl Sideart
« Reply #1 on: August 21, 2006, 12:07:33 am »
I don't know if you'll be screwed applying it but you might be screwed if classicarcadegrafix hasn't improved their horrible quality.
toe.
  • Last login:March 23, 2014, 05:13:30 pm
« Reply #2 on: August 21, 2006, 07:46:11 am »
a good vinyl will remove latex paint in sheets. so if you ever plan on removing/ changing your graphic...
latex is bad!
ChicagoDave
  • Last login:May 18, 2023, 11:08:23 am
    • Dave's Website
« Reply #3 on: September 03, 2006, 05:22:39 pm »
I was just ready to apply my side art also when I read this post.  I am also using a latex paint on my cabinet.  Has anyone had success with this, or are there only some rare cases where there can be a problem?
Homer Simpson:
"Here's to alcohol, the cause of, and solution to, all life's problems."
zenmasterbooty
  • Last login:November 10, 2017, 08:44:17 pm
  • Deus Ex Machina Turbo
« Reply #4 on: September 06, 2006, 12:24:27 pm »
Yes... You very well could be.
We used vinyl stickers all over our cab, and the only place we had a problem was on the front doors where we had applied paint. The vinyl began to delaminate with in the first 6 months and had to be reapplied. I think your best bet would be to sand off the paint before applying the vinyl to avoid the same problem.
