Author Topic: Arcade Controls  (Read 2364 times)
patm95
  • Last login:January 11, 2026, 10:16:48 pm
Arcade Controls
« on: August 15, 2006, 10:58:00 pm »
I am just now starting to plan my cabinate.  I am looking forward to planning my control panel, trying to decide what controls would be best.  I am looking for some advice from my fellow enthusiats.
I am looking to design a 4 player CP.  For player 1-2, I was thinking about the happs rotary optical joysticks.  This would enable me to play games like Ikari warriors and have the 8 way control.  For players 3-4, the happ competition joystick, a cheaper 8 way.  An Ultimarc e stick for 4 way games with the option to rotate for Q Bert. A push-pull spinner for games like tron (Apache controls).  Last but not least, I would like to mount a trackball for games like centipede and golden tee.  I have not sorted out a layout yet, but as you can probably tell, I am trying to design a panel that would enable me to play the largest variety of games possible.  Thinking about an aviation joystick, but just not sure if I would have the space to mount it lol.
So does this sound like a good combination?  Criticism is appreciated!  Thanks.
horseboy
  • Only Saint has those powers.
  • Last login:March 07, 2021, 02:19:14 pm
  • With my last breath, I curse Zoidberg!
Re: Arcade Controls
« Reply #1 on: August 15, 2006, 11:07:37 pm »
You want the mechanical rotaries
Quote from: saint
saint is all powerful.
Apparently he is.
NightGod
Re: Arcade Controls
« Reply #2 on: August 16, 2006, 01:45:31 am »
I think you'll run out of room before you get that aviation joystick mounted. I'm building a massive CP (48x20) and have basically the same thing you have listed there, no way I could fit in an aviation stick, there just simply isn't the room for it.
patm95
Re: Arcade Controls
« Reply #3 on: August 16, 2006, 07:28:11 am »
Thanks for the input guys, I will look into the mechanical rotaries too.  I guess the aviation stick wouldn't be a huge loss, if I couldn't fit it on the CP.  I just thought it would be cool to have it.
horseboy
Re: Arcade Controls
« Reply #4 on: August 16, 2006, 09:49:24 am »
You could always go with swappable cp's.
Quote from: saint
Apparently he is.
RobotronNut
  • Last login:December 22, 2018, 11:39:19 am
Re: Arcade Controls
« Reply #5 on: August 16, 2006, 02:30:38 pm »
any panel wide enough to fit 4 players must be able to fit a flight stick. it doesn't have to be in the same row as the sticks for the 4 players. my 2-player panel is 35" wide, and it fits a flight stick very comfortably.
you just need to make a mock-up, to make sure your forearms don't bump into controls in the lower row.
to see my "Frankenpanel" and design notes, click here.
ahofle
    • Arcade Ambience Project
Re: Arcade Controls
« Reply #6 on: August 16, 2006, 02:40:51 pm »
Nice looking CP there...where did you get that flight stick?
RobotronNut
Re: Arcade Controls
« Reply #7 on: August 16, 2006, 04:40:07 pm »
i had slikstik include the (optional) flight stick when they built my panel.
the flight stick is a Happ Heavy Duty 8-Way Trigger Joystick with 2 Fire Buttons (you need at least one "fire button" (=thumb button) for discs of tron).
you can get them directly from happcontrols.com, or probably less expensively from divemaster127 or ponyboy.
« Last Edit: August 17, 2006, 04:12:00 am by RobotronNut »
RobotronNut
Re: Arcade Controls
« Reply #8 on: August 16, 2006, 05:09:27 pm »
btw, standard mame builds don't support the rotary properly. i run MameAnalogPlus for rotary games and standard mame for all others.
also, i've found that i'm not as excited about rotary games as i thought i would be. if i had it to do over again, i might replace the rotary with a second flight stick. 2 flight sticks would be awesome for tank games.
patm95
Re: Arcade Controls
« Reply #9 on: August 16, 2006, 11:05:19 pm »
While we are on the subject of controls, I am not planning on having a keyboard hooked up at all, just for authenticity.  What administrator buttons are recommended?  I guess I will need at least 1 for exiting the game?  I plan to just use tokens for credits.  I would like to keep the administrator buttons hidden if possible and kept to a minimum.  Maby back of the cabinate?
AtomSmasher
    • Atomic-Train
Re: Arcade Controls
« Reply #10 on: August 16, 2006, 11:09:39 pm »
pause, exit game, menu, and "enter" to navigate the menu
TehJefe
  • Last login:November 20, 2006, 11:54:05 am
  • Oh Tyler, save me! Deliver me!
Re: Arcade Controls
« Reply #11 on: August 17, 2006, 02:30:04 am »
+a coin button if youre into that kinda thing... far be it for me to pass judgement.  ;)
Do you really need an enter button? Cant that just be like.. any specific button on the cp?
And a good place to hide those admin buttons would be underneath or on the sides of the cp.
