Author Topic: question about replacing bottom of cabinet?  (Read 4926 times)
Smirnoffinator
  • Last login:August 06, 2010, 11:02:51 am
« on: July 30, 2006, 04:19:05 pm »
I just got a jamma cab and it is my first.  Well I dont need it to be perfect but the bottom has some water damage and I have a large enough piece of wood to replace it.  Is there a best practice to go about this without dissassembling the whole cabinet??
NightGod
Re: question about replacing bottom of cabinet?
« Reply #1 on: July 30, 2006, 05:09:45 pm »
Water Damage base repair - Generic BnB cabinetOne of the stickies in this forum :D
Smirnoffinator
« Reply #2 on: July 30, 2006, 05:22:50 pm »
No I mean the actual bottom of the cabinet not the lower part of a side.  Just the bottom and nothing on the side.  Thanks
nostrebor
  • Not enough wit to effectively use this space...
  • Last login:October 04, 2013, 02:02:41 pm
  • SHOCKING!!
« Reply #3 on: July 31, 2006, 08:42:32 am »
Really hard question to answer without pics. It wont be easy to do without some disassembly of the cabinet.
NightGod
« Reply #4 on: July 31, 2006, 09:26:20 pm »
You could probably avoid disassembly by jigsawing the old one out and putting the new one in with pocket screws to avoid having to screw in from the outside.
« Reply #5 on: August 01, 2006, 04:41:46 pm »
You wouldn't have to disassemble the cab... I'd probably jigsaw most of it out, then use a chisel to get the rest out, then replace as it was originally.
nostrebor
  • SHOCKING!!
« Reply #6 on: August 01, 2006, 05:11:16 pm »
Assuming that it's not a Williams, Taito, or one of the many other cabinets that had dados that the bottom fit into. If your going stock replacement on one of these, the floor is bigger in dimension than the inside dimensions of the cabinet.
This is why this thread is useless without pics.
Until pics appear, we're all just talking smack.
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #7 on: August 01, 2006, 10:56:43 pm »
You're a doody head and your mother dresses you funny ;D
« Reply #8 on: August 02, 2006, 11:42:41 am »
Okay, then, jigsaw the piece out, chisel the leftovers, then route out the dado slot...
OH, rainBOWS.  You would have to slightly disassemble the cab in order to put the new piece into the dado slots.
This does beg the question... if you have to go to this level of repair on a cab, does using the exact original method matter?  Sure, maybe the original method would require disassembly, but couldn't you do the repair by gluing/screwing from the outside/support pieces underneath?
nostrebor
  • SHOCKING!!
« Reply #9 on: August 03, 2006, 09:42:17 am »
You could do this repair any of two dozen different ways...
I would be glad to supply one educated answer, based on posted pics.
And Drew blows Goats. ;D
