November 21, 2009, 09:00:25 AM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News:
   Home   Help Arcade Search Login Register
Main Woodworking Reviews Software Monitor/Video
Audio/Jukebox/MP3 Project Announcements Artwork Consoles Buy/Sell/Trade
Arcade Miscellaneous Everything Else Politics n Religion Forum Discussion Wiki Discussion
DOS/WinCab PowerMAME SK Jukebox UncleTs Jukebox Project Arcade
Linux Restorations Pinball MaLa Frontend
Recent posts | Arcade | Rules | Old Boards | Old Archives | Chatroom | Wiki | File Repository | RSS
Pages: [1]   Go Down
  Send this topic  |  Print
Author Topic: Water Damage base repair - Generic BnB cabinet  (Read 12016 times)
nostrebor
Not enough wit to effectively use this space...
Wiki Contributor
Trade Count: (+6)
Full Member
Offline Offline
SHOCKING!!
View Profile
« on: February 11, 2006, 10:04:06 AM »
I'm working on a real basic consignment project right now. It is a multiple-converted Joust cabinet, that had significant damage at the bottom featuring repairs by an OP that were less than stellar. Wink
I'm not goint to spend a bunch of time featuring the actual cabinet build, as it is nothing that has not been done a thousand times before. I did take the time to document the bottom repairs, so I'll share the pics and info in this thread.
This is a significant process that is much less difficult to accomplish if you own a table saw and a dado blade set, but it could be done effectively with a sawboard, circular saw with a good blade, and a router with a 1/4" straight bit.
(sawboard link)
http://forum.arcadecontrols.com/index.php?topic=43568.0
On to the pics...
« Last Edit: February 11, 2006, 10:36:54 AM by nostrebor » Logged
nostrebor
Wiki Contributor
Trade Count: (+6)
Full Member
Offline Offline
SHOCKING!!
View Profile
« Reply #1 on: February 11, 2006, 10:08:42 AM »
1st pic shows the damage. This thing was toast! I cleared the area to be sawn of metal bits and chose a point to saw across.
2nd pic shows the setup with my sawboard and the circular saw. This particular sawboard is an aftermarket setup with a guide angle and a roller-bearing guide plate that mounts to a circular saw. It was a Christmas gift and it's really nice, but a sawboard like the one detailed in the link above will do just as well.
« Last Edit: February 11, 2006, 10:42:07 AM by nostrebor » Logged
nostrebor
Wiki Contributor
Trade Count: (+6)
Full Member
Offline Offline
SHOCKING!!
View Profile
« Reply #2 on: February 11, 2006, 10:15:45 AM »
3rd pic... Once the measuring for square is done and checked twice and the sawboard is secured, I make the cut. I carefully set my blade depth to not quite cut all the way through the face of the plywood. I'll clean up this edge after the fact.
4th pic... the cut is made! and the bad stuff is removed. The original cabinet had dados (slots) cut in it to align the parts. I'll be re-using the "tabs" on the bottom, front and back of the cabinet to strengthen the glue-up of the new piece.
5th pic... closeup showing the bit of fibers left after removing the bad parts. Also shows the factory tongue that will stick into the grooves that I will be putting in the back of the patch. On a williams cabinet you also have to dig out the spring steel "nails" that they used to hold stuff together. These are hell on a saw blade, so if you do this repair, you might want to have a spare blade on hand.
« Last Edit: February 11, 2006, 10:38:07 AM by nostrebor » Logged
nostrebor
Wiki Contributor
Trade Count: (+6)
Full Member
Offline Offline
SHOCKING!!
View Profile
« Reply #3 on: February 11, 2006, 10:19:22 AM »
6th pic... all the old glue is scraped off, the fibers are cleaned up, the steel bits are removed, and measurements are taken for the new piece.
7th pic... the new patch is cut to fit. I'm using MDO plywood for this because I had some Smiley It is 7-ply with marine grade glues and a paper face that is water resistant. It's primary use is sign board in outdoor applications - great for the base of a cabinet!
Logged
nostrebor
Wiki Contributor
Trade Count: (+6)
Full Member
Offline Offline
SHOCKING!!
View Profile
« Reply #4 on: February 11, 2006, 10:25:19 AM »
8th pic... I used biscuits and a biscuit jointer to align the face of the factory plywood with my new patch. If you do not have a biscuit jointer you can use a thin strip of plywood on the inside face, or just butt up the faces and glue. (Note:If you do the butt joint method, it is more difficult to get everything to line up, but it can be done.)
9th pic... all mating surface are glued and the new patch is clamped in place. Harbor Freight runs sales on these "F-clamps" all the time for $3-$5 per clamp. They are cheap, work great, and you can never have too many Cheesy
« Last Edit: February 11, 2006, 10:39:42 AM by nostrebor » Logged
nostrebor
Wiki Contributor
Trade Count: (+6)
Full Member
Offline Offline
SHOCKING!!
View Profile
« Reply #5 on: February 11, 2006, 10:29:45 AM »
Final pic after paint. It's a bit dusty, but the patch is all good.
Edit: I forgot to mention... I used plastic filler (bondo) for the seam fill and a longboard for sanding the joint between the old and new to a flat uniform surface. A longboard is just a 16" long sandpaper holder used for automotive bodywork. Real cheap to pick up and great for getting flat uniform surfaces. You want to sand at an angle across the joint, longways to get to flat, and then sand with the grain to get rid of sanding scratches. I used a fairly heavy primer to help fill blemishes as well. A good friend sprayed the black for me with an airless Cheesy It was the easiest paintjob I have done yet Tongue
« Last Edit: February 11, 2006, 04:07:47 PM by nostrebor » Logged
miles2912
Trade Count: (0)
Full Member
Offline Offline
My first Home Game. Fairchild System F.
View Profile
« Reply #6 on: February 11, 2006, 01:01:30 PM »
Great tutorial thread on how to repair a damaged cab.  You are right on about having the correct tools for the job.  Sure makes you life easier..
We have a board for Hall of Fame cabinets, we need one for Hall of Fame posts.  Almost a Board for nothing but FAQ's and then lock the thread.  This is one of the posts that belong in something like that.
Don
Logged
Chief Kicker - Nobody's perfect, including me. Fantastic body.
Trade Count: (+11)
Full Member
Offline Offline
View Profile
« Reply #7 on: February 21, 2006, 10:44:18 AM »
I hadn't noticed this until you mentioned it elsewhere... this is awesome.  Sticky worthy, IMO.  Thanks for doing it.
Logged
SirPeale
Green Mountain Man
Global Moderator
Trade Count: (+20)
Full Member
Offline Offline
Arcade Repair in New England
View Profile WWW
« Reply #8 on: February 21, 2006, 08:50:14 PM »
Sticky worthy, IMO.
Done!
Logged
nostrebor
Wiki Contributor
Trade Count: (+6)
Full Member
Offline Offline
SHOCKING!!
View Profile
« Reply #9 on: February 22, 2006, 12:11:16 PM »
Thanks for the comments and sticky!
I may add some more pics and detail in the future to this one, and look for future write-ups on other fun aspects of conversion-to-mame builds.
Dave.
Logged
markrvp
ARGHHHHHHHHHHHHH!!!!!!!!!! True Genius!
Wiki Contributor
Trade Count: (+4)
Full Member
Offline Offline
NFL Expert
View Profile
« Reply #10 on: February 22, 2006, 03:33:28 PM »
Excellent tutorial.  I can't believe there isn't a visible line.  Pretty amazing.
Logged
Tahnok
Trade Count: (+1)
Full Member
Offline Offline
Error recording error codes. Remaining errors lost
View Profile WWW
« Reply #11 on: February 24, 2006, 01:29:00 AM »
Good tutorial, what what's with the sawboard? That clearly isn't the same one that you linked to. Did you modify it with a track and sled? I was looking at putting something like that together a while ago and would love to see what you have done.
Logged
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
nostrebor
Wiki Contributor
Trade Count: (+6)
Full Member
Offline Offline
SHOCKING!!
View Profile
« Reply #12 on: February 24, 2006, 10:33:09 AM »
It is mentioned in my second post:
It came from Penn State Industries - on sale for $69 when I got it.
http://www.pennstateind.com/store/ps.html
Logged
Tahnok
Trade Count: (+1)
Full Member
Offline Offline
View Profile WWW
« Reply #13 on: February 24, 2006, 03:34:41 PM »
I don't know how I missed that. $69 on sale? That's exactly why I'm building my own.
Logged
nostrebor
Wiki Contributor
Trade Count: (+6)
Full Member
Offline Offline
SHOCKING!!
View Profile
« Reply #14 on: February 24, 2006, 09:50:10 PM »
It was spendy, but there a 5 roller bearings on the saw mount. Once you have the plate engaged onto the track, it is as accurate as a table saw, with no effort to keep it aligned. You just close your eyes and push, and get perfect cuts.
It's one of my favorite tools!
Logged
teetu
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #15 on: March 05, 2006, 02:38:45 PM »
the router "sled" for that system seems pretty nice too.  I made a sawboard for my router, but quickly realized the thickness of the sawboard complicated things.
Logged
Hiub1
Trade Count: (+1)
Full Member
Offline Offline
www.sleepyjack.com
View Profile
« Reply #16 on: April 16, 2006, 10:36:23 PM »
Am I the first one to try? Thanks for the great tutorial, it really helped me out.
http://forum.arcadecontrols.com/index.php?topic=52803.0
We'll see if i can get it as good as yours!
Logged
mmmPeanutButter
Trade Count: (0)
Full Member
Offline Offline
better living through gaming
View Profile
« Reply #17 on: April 21, 2006, 09:54:53 AM »
I did pretty much the exact same thing on my centipede cab (made it a little taller while I was at it).  I used a dowling jig instead of biscuit joiner.
The one thing I screwed up was using plywood.  Plywood sucks.  I should have gone with mdf or particle board.
Although when it was all done with the graphic on, it didn't really make a difference.  It just made the prep really tough.  Just thought I'd pass that little tid-bit along.
Logged
I
theCoder
Trade Count: (0)
Full Member
Offline Offline
I'll clean up my mess, Honey, when I'm done...
View Profile
« Reply #18 on: May 02, 2006, 10:54:31 PM »
Did you reinforce the joint in the top center?
Logged
97thruhiker
Trade Count: (+2)
Full Member
Offline Offline
View Profile
« Reply #19 on: May 26, 2006, 12:40:14 PM »
Great post.  Getting ready to go the next Super Auctions in Orlando on the 17th and this may actual help me to bid on a cabinet.  I built my current cabinet from scratch and enjoyed every minute of.  I have always been hesitant to buy an old cabinet because I was not sure how to go about fixing it (seemed like it would more of a hassel).  While I'm not saying what you did here was easy it just put it into a perspective that I know I could do that and I have the tools to get it done.  Thanks!
Logged
Hippie459MN
Trade Count: (0)
Full Member
Offline Offline
I really need to edit this.
View Profile WWW
« Reply #20 on: July 31, 2006, 11:07:16 PM »
Thanks for the great little tutorial. Looks like I am gonna save my old cab I got for $5 after all. I origanlly bought if for a few parts but never ended up using them so I just might mame it after all.
Thanks a ton!
Logged
Long live Donkey Kong Jr.!!!!
Haunton
Trade Count: (0)
Full Member
Offline Offline
Darth Vader "I find your lack of faith disturbing"
View Profile
« Reply #21 on: May 13, 2009, 10:29:35 AM »
great walk through....i recently got about 14 arcade cabinets (fully functional with board and monitor) that have pretty horrible water damage at the base. I was going to scrap them ....mabey with this info i can save a few.
Logged
Pages: [1]   Go Up
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.10 | SMF © 2006-2009, Simple Machines LLC | Sitemap Valid XHTML 1.0! Valid CSS!
Page created in 0.298 seconds with 36 queries.
