Author Topic: Spinner bushing question  (Read 1013 times)
ahofle
    • Arcade Ambience Project
« on: July 21, 2006, 11:29:32 am »
I recently decided to redo the vinyl control panel overlay under my lexan because you could see my carpentry imperfections (trackball mounting plate outlines and also a wrinkle here and there).  I used this thin rigid plastic sheeting and put the new overlay on it, and then the lexan over that.  It worked perfectly, however as thin as the sheeting is, I have slightly raised the height of the CP and as a result my Oscar spinner knob doesn't attach very well to the shaft anymore because there isn't much room on the shaft past the little white spacer/bushing thing where I can attach it with the set screw.  My question is...can I grind the little bushing down a little to give more room?  It seems very smooth on both ends and I wasn't sure if roughing up one end with sandpaper would change the spinning characteristics.  Any other suggestions?
Thx,
Andy
« Last Edit: July 21, 2006, 11:34:54 am by ahofle »
fatfingers
  • Got UltraStiks?™
Re: Spinner bushing question
« Reply #1 on: July 21, 2006, 11:51:25 am »
Could you just route the bottom of the control panel a little so that the spinner will sit up a little higher?  Then you wouldn't risk damaging the spinner.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
