Author Topic: Wells Gardner K7200 19" Schematics  (Read 2665 times)
CPickler
  • Last login:August 20, 2006, 02:37:14 am
    • CPU Studios
« on: July 12, 2006, 10:56:43 pm »
Does anyone have the schematics for this monitor.  I bought mine new and it didn't come with schematics or anything to explain which controls on the mainboard do what.  Also I would appreciate it if you could tell me which pins on the molex connector correspond to which VGA outputs.  I am using a VGA breakout cable from Ultimarc and using their ArcadeVGA as well.
Thank you, also, where can I get a 10 pin female molex connector with the clips so I can actually connect my VGA breakout cable to the monitor.
Kevin Mullins
    • Me on Myspace
Re: Wells Gardner K7200 19" Schematics
« Reply #1 on: July 14, 2006, 04:17:23 pm »
What is the exact model number of the one you bought?
They have a few variations of the 7200.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: July 15, 2006, 12:41:40 am »
Telephone the parts department (1-800-336-6630 or 708-290-2100) at Wells-Gardner and order part number 069X2848-100 Product Manual 19" K7200 series. That's what Wells calls a service manual. It includes schematics, theory of operation/sequence of events, and parts list.
The 10 pin Molex video/sync input connector is Molex # 09-50-7101 or Wells-Gardner part # S03D0000-000F Signal cable assembly with 10 pin connector.
CPickler
    • CPU Studios
« Reply #3 on: July 15, 2006, 05:29:09 am »
Thank you very much.  For the terminals inside the housing do I need 08-50-0106, or do you recommend a different one?
Ken Layton
  • Guru
  • Technician
« Reply #4 on: July 15, 2006, 10:42:01 am »
The Wells part number for the cable assembly includes the pins already crimped to the wires & inserted into the housing----a cable assembly!
CPickler
    • CPU Studios
« Reply #5 on: July 15, 2006, 12:47:38 pm »
ok, Thank you very much.
