Author Topic: Z26 Emulator Help. I need you guys to help test something.  (Read 1577 times)
mccoy178
  • Trade Count: (+9)
  • Last login:August 20, 2026, 01:21:00 pm
  • Go Bucks!
« on: June 29, 2006, 12:34:00 pm »
Okay.  I have Z26 in my Atari2600 Roms folder.  I have a .cli with the following command:
-v18
From the acrobat file, it says that -v1N should open Z26 in a window with N video mode.  I can't get this command to work.  Could someone please try this and let me know if and how they were able to get it to work.  I am attempting to use this on a component t.v. and the only way it is playable and viewable is with this setting.  I have had it running in X26, but I would like to get it going in Z26. :banghead:  Thanks in advance for your help.
arcadegamenut
  • Last login:July 16, 2010, 01:48:45 pm
Re: Z26 Emulator Help. I need you guys to help test something.
« Reply #1 on: June 29, 2006, 01:49:51 pm »
I'd say to double-check your config file and make sure the v is a lowercase v and not an uppercase V.
For me, when I used V (uppercase), it did nothing. Otherwise, v (lowercase) worked fine.
Granted, this was all on a PC monitor, but still...can't hurt to double-check.
Here is the command I ran at the prompt:
c:\emu\atari\z26> z26 -v18 combat
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #2 on: June 29, 2006, 09:15:49 pm »
 :banghead:  Thank you very much.  I just realized that I was dropping the roms onto z26 instead of using a command prompt when testing.  I just went and tried it out and all is well.  :banghead:
