Author Topic: Brown CRT..? + TV problems (sort of..)  (Read 2265 times)
kspiff
  • Last login:February 02, 2016, 09:15:36 pm
  • Love of the game, baby.. love of the game..
« on: March 09, 2003, 02:12:38 am »
I read at the 8liners site yesterday (when looking at the TV -> RGB monitor chassis) that you can judge a CRT by its color and that gray is good and brown is bad.. the old Electrohome G07-CBO I'm about to try to fix has a reddish-brown color tube (at least under the anode cap -- currently the cleanest spot on the tube).  Should I even bother trying to fix it, or does this mean the tube is definitely/100% busted?
Also another question.. I have a 25" TV I want to convert into an arcade monitor with the 8liners chassis.. currently, the TV works but the screen contracts to almost nothing when the tube gets warmed up.  This -- I would assume -- has nothing to do with the CRT itself, does it?  Don't want to convert and then have the same issue.
k-spiff
dhansen
  • Last login:November 28, 2025, 10:41:14 am
  • No Quarters Needed
    • Arcade Stupidity
Re:Brown CRT..? + TV problems (sort of..)
« Reply #1 on: March 09, 2003, 02:37:30 am »
He means the front of the screen being brown...some older CRT have a brownish color to them.  Careful with the Electrohome, I can't get the pincushioning out of mine and the 8liners guy wasn't too helpful, here's his reply:
Hi,
 It seems that the chassis is not compatable with this tube....
Try it in another picture tube.
 Did you read my tech info at:
http://www.Genao.com/datatech/monitor.html
 Regards,
  Victor Genao
http://www.8liners.com
Doug Hansen wrote:
> Hello Vic,
> I'm getting some pretty bad pincushioning that I can't adjust out on one of
> my monitors is there a way to remedy this?  Also, I may have ordered the
> wrong chassis for one of the monitors.  It has eight pins but the neckboard
> is too small and won't fit on the yolk.
> Here's a pic of the one I'm having trouble with.
> Doug
He seems to keep pointing you back to his web page that isn't very detailed so be careful on which one you order, the electrohome had 8 pins but it used a 10 pin neckboard.  The 8-pin neckboards do not fit on the electrohome monitors.  Luckily I had another Wells Gardner that this board did work on.
I'm not sure about your second question...sorry...
Doug
..as his cold lifeless fingers lie motionless on the garage floor, all he could hear in his head was...I JUST WANTED TO PLAY A GAME OF DONKEY KONG!!
kspiff
« Reply #2 on: March 09, 2003, 05:16:48 am »
Oh, no.. the Electrohome tube is going to be reattached to to its original chassis after I attempt to repair (pretty much rebuild/replace) it.
I don't think the tube is bad on the 25" TV, though, giving it some thought.. it likely wouldn't display any picture at all.. and when the image isn't too large/small it looks pretty good.
k-spiff
