Author Topic: Newbie Needs Advice on Monitor  (Read 1877 times)
ldl
  • Last login:April 20, 2020, 07:51:27 pm
« on: June 23, 2006, 07:41:02 pm »
I have a 21" Intergraph Monitor that i want to use in a cab. It has R,G,B, H-Sync, V-Sync connections at the back and the label says 50/60 Hz. Would this monitor be capable of running at arcade resolutions and if so is it really necessary. Thanks.
grantspain
Re: Newbie Needs Advice on Monitor
« Reply #1 on: June 24, 2006, 06:51:54 am »
is the cab mame or standard arcade board?what model no. of the monitor?
ldl
« Reply #2 on: June 24, 2006, 07:04:14 am »
It's for a mame cab. Model# TX-D2162W (Intergraph 21sd95). Thanks
grantspain
« Reply #3 on: June 24, 2006, 07:23:10 am »
well according to what i just read thats a svga monitor so it will work on a standard graphics card,what type of plugs for signal input are on the back?
Kevin Mullins
    • Me on Myspace
« Reply #4 on: June 24, 2006, 11:12:55 am »
I would think you could make a breakout cable and come straight off the vga card.
ldl
« Reply #5 on: June 24, 2006, 04:26:57 pm »
The  monitor also has the standard vga connector. I guess what I really wanted to know if it would be capable of handling those 15khz arcade signals that I am reading so much about.
Q*Bert_OP
  • Oh yes, we did!
« Reply #6 on: June 24, 2006, 06:26:16 pm »
If you're using it with mame,  it's just fine, because your computer will convert those refresh rates to make it compatable with a computer monitor, but if you are using real arcade pcbs, you will need an arcade monitor.
ldl
« Reply #7 on: June 24, 2006, 09:54:24 pm »
Thanks for the reply
