Author Topic: W/G 25" weird green lines  (Read 1964 times)
68ragtop
  • Last login:September 21, 2007, 09:27:42 am
« on: June 22, 2006, 06:55:41 pm »
Hi Guys,  I have a MKII with a W/G 25K7197, with a Philips Mo8X CRT.
It has faint green horizontal lines sweeping through the screen that slope slightly, & are about 1 1/4" apart, top to bottom.   They don't adjust out, & I am not sure what to look for.  I have the service manual for it, But was hoping someone might be able to help me locate the problem.
Thanks, Carl
Ken Layton
  • Guru
  • Technician
Re: W/G 25" weird green lines
« Reply #1 on: June 22, 2006, 07:00:52 pm »
Turn the "screen" control on the flyback down slightly (counterclockwise).
68ragtop
« Reply #2 on: June 22, 2006, 08:22:31 pm »
You Got it!   Thanks, That was quick!
Do you know if there is a horizontal position adjustment on these?
Seems the image is about 1" from the top & all I have is a horizontal
size adjustment.  I basically adjust the size until the bottom is correct, but
it leaves the image 1" low on the top.
Thanks again,  I now have a nice bright picture on a black screen!
No green lines :cheers:
Kevin Mullins
    • Me on Myspace
« Reply #3 on: June 22, 2006, 09:36:58 pm »
An MKII is a horizontally mounted monitor..... so are actually asking about a "vertical adjustment" since you need to move or resize the picture up and down?
68ragtop
« Reply #4 on: June 23, 2006, 08:19:54 am »
Sorry, your right.  It has horizontal size & position adjustments But only verticle size.  So I don't seem to have a way to change verticle position.
Carl
Kevin Mullins
    • Me on Myspace
« Reply #5 on: June 23, 2006, 09:45:01 am »
Do you have the manual? (K7000)
Does your monitor have the remote adjustment board?
Those generally have a vertical raster position pot on the back of the chassis along with the others or a vertical pos on the remote board.
You may need to find the transistor Q9 on the chassis and check it.
