Author Topic: Car window tint removal.  (Read 2512 times)
fastredpacman
  • Last login:February 19, 2018, 02:12:36 am
  • What?
« on: June 17, 2006, 07:50:34 pm »
Any one have any ideas how to remove tint especially in the back where the window defroster is without damaging it?
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
Re: Car window tint removal.
« Reply #1 on: June 17, 2006, 09:24:20 pm »
Razorblade
For the old school :)
Or a heat gun.. heat, peel, repeat..
pointdablame
  • Last login:April 01, 2026, 10:20:52 pm
« Reply #2 on: June 17, 2006, 10:03:57 pm »
without damaging the defogger?  or damaging the tint?
Take a razor blade to the glass and just peel away the tint.  Cut between the defroster lines if you're really worried about it, but you shouldn't do any damage.
You can't save tint... I doubt that is what you were saying, but just in case... that tint is ruined... you can't take it off without damaging it.
first off your and idiot
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #3 on: June 17, 2006, 11:02:11 pm »
I think the defroster lines are what he's concerned about. They are basically stuck on to the window, and a razor blade might cut or damage them.
Let me know how it goes Fast, I need to remove my tint too.
NO MORE!!
SOAPboy
  • ..::GeeK::..
« Reply #4 on: June 17, 2006, 11:19:58 pm »
Heat gun
It peels right off.. seriously
fastredpacman
  • What?
« Reply #5 on: June 18, 2006, 12:00:47 am »
I was worried about the lines not the tint. Have any of you ever tried other methods other than a heat gun?
toe.
  • Last login:March 23, 2014, 05:13:30 pm
« Reply #6 on: June 18, 2006, 12:46:42 am »
the best method is really using the heat gun o n
the outside of the window (get a friend to help you),
peel from the inside,
starting at the corners with either a hardcard or
a plastic  putty trowel.
 once you get a good lift, it shouldnt take you more
than 10 minutes to get it done with your fingers.
SOAPboy
  • ..::GeeK::..
« Reply #7 on: June 18, 2006, 01:47:07 am »
Yes, ive used "glue removers" for tint, razor blades, sand papers, and heat guns..
Heat guns work the best..  Close second, is razors + Glue removers (but) = Messy as hell
missioncontrol
  • MC-Retro says Wot!
  • Trade Count: (+13)
« Reply #8 on: June 18, 2006, 01:58:06 pm »
just buy a new car insted
fastredpacman
  • What?
« Reply #9 on: June 18, 2006, 04:22:56 pm »
You are f:censored: nuts but at least  :laugh2:
usedelectronics
  • Last login:January 06, 2019, 02:57:37 am
« Reply #10 on: June 19, 2006, 12:19:19 am »
no no no.... Heat gun method leaves LOTS of glue behind typically.
Try this:
Get industrial grade ammonia cleaner at the hardware store. And a roll of saran wrap from the grocery store.
On a hot sunny day, spray the ammonia on the window film from the inside wetting the entire surface.
Working quickly, smooth saran wrap over the ammonia trapping it against the film.
Leave window with saran wrap and ammonia in direct sunlight for at least a hour.
Then SLOWLY peel the tint and saran wrap together.
Usually both layers of tint {tint layer and glue layer} will peel off almost completely in one piece this way, and no razor blade damage.
SOAPboy
  • ..::GeeK::..
« Reply #11 on: June 19, 2006, 04:00:05 am »
Try this:
Yeah, it leaves some glue.. you can get the glue off really easy with the tint glue removal stuff..
missioncontrol
« Reply #12 on: June 19, 2006, 05:40:36 am »
Try this:
hmmmmm.......... breathing ammonia fumes inside a hot car you forgot to mention the part where he's supposed to keep the windows rolled up and it's best to do it when it's close to 100 degrees outside too.........
Clonedsheep
  • Last login:March 29, 2025, 09:59:42 pm
« Reply #13 on: June 19, 2006, 12:48:12 pm »
Try this:
    Yeah, Alot of tinting places just use windex and a razor. I didn't know about the saran wrap, cool tip.
The king of 1/2 done projects
