Author Topic: OK, I need slight "How To" in running MAME command prompt....  (Read 1901 times)
postalp123
  • Last login:March 18, 2024, 09:07:50 pm
  • Retro-gamers don't just play, they reminisce.
As with my earlier post, I am running MAME DOS.
In order to create a Config File for MAME, it say the following:
MAME is a console application, you should launch it from a command prompt.
Usage:    MAME  -createconfig / -cc
   Creates the default MAME.INI file. All the following configuration
   options can be permanently changed by editing this configuration file.
etc....
OK, so I've tried starting DOS by running "Command", the DOS box opens and I get this:
C:\DOCUME~1\PC-1>
From there I'm at a loss.
Any help would be super!
SirPeale
  • Green Mountain Man
Re: OK, I need slight "How To" in running MAME command prompt....
« Reply #1 on: May 09, 2006, 01:04:42 am »
Started DOS, or running a command prompt?  From the looks of things, the latter.
Either way, you need to learn how to use the "CD" command.
I recommend getting a DOS book on basics and start reading.
gonzo90017
« Reply #2 on: May 09, 2006, 01:43:09 am »
Go to http://www.gabrieleponti.com/software/ and download Sendtotoys. When installing the program uncheck everything except command prompt. When you're done just right click on mame.exe and highlight and click on command prompt. Now type configure --cc
