Author Topic: How can I create a list of non-working games?  (Read 1722 times)
gonzo90017
« on: May 06, 2006, 12:32:39 am »
Pi
  • Last login:March 08, 2007, 03:46:13 am
  • From Jupiter with pride
    • CAESAR
Re: How can I create a list of non-working games?
« Reply #1 on: May 06, 2006, 06:32:44 am »
This is how I would do it:
1. Get Logiqx's DatUtil, transform a MAME XML into tab-delimited text keeping details (-k), load in a spreadsheet, and discover which column has the driver status. IIRC it is the first data column in the game_driver rows (so you just need those rows). Sort accordingly, remove the crap, leave the list.
Or:
2. Go to MAWS, select Browse, select by "driver status", select imperfect or preliminary, and copy the list from your browser.
Note that "non-working" games is a loose definition which varies from game to game. Some games marked as non-working can be played, and some games marked as "imperfect" are unplayable.
Pictures in the dark I see - Morpheus comes to me.
  • Last login:May 05, 2026, 10:44:49 pm
« Reply #2 on: May 06, 2006, 05:32:59 pm »
Or:
What he said.... the short of it, is you really can't make a list of non-working games as mame doesn't output a non-working list.
Imperfect can mean anything from player 3's inputs aren't hooked up to the game *might* crash if you press up 4 times in front of a window in level 5.  I've also found the prelimenary tag to be mis-leading.  In a few instances even those games are playable, they might just have the wrong color pallette or no sound or something.
mackem
  • Last login:May 07, 2006, 09:44:02 am
« Reply #3 on: May 06, 2006, 08:57:16 pm »
http://www.mameworld.net/maws/gamelist.txt
It looks like you have to copy and paste that link into your browser. Direct linking doesn't work.
« Last Edit: May 06, 2006, 08:59:22 pm by mackem »
Pi
    • CAESAR
« Reply #4 on: May 06, 2006, 10:10:27 pm »
Gamelist doesn't list clones, unfortunately. Never did, and current renditions of the old file (in MAWS and also in DatUtil) don't do them either.
