Author Topic: Create a mame main ini  (Read 1546 times)
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
« on: May 02, 2006, 06:34:09 pm »
how do i create a mame ini file as i dont have one. I know you type in some command on command prompt but i cant get it right im not used to dos commands
gonzo90017
Re: Create a mame main ini
« Reply #1 on: May 02, 2006, 06:49:22 pm »
Download Send to Toys http://gabrieleponti.com/software/ When installing it uncheck everything except command prompt. Once installed right click mame.exe then highlight and click command prompt. Now type configure --cc
Marky_1979
    • Personal Webspace
« Reply #2 on: May 02, 2006, 06:56:50 pm »
Thankyou so much :) Iv been here for 3 hours trying everything. My next problem lies in the ini whats wrong or missing from this file?
« Last Edit: May 02, 2006, 07:27:47 pm by Marky_1979 »
gonzo90017
« Reply #3 on: May 02, 2006, 10:59:03 pm »
Is it not working? Did you try running a game?
Same method as above just type the name of the game instead of configure --cc
example for double dragon: mame.exe ddragon
Looks  fine. I would change
skip_disclaimer         1
skip_gameinfo           1
resolution              640x480 or 800x600
depends what kind of monitor you have since I have a crt. It prevents out of range errors. If you need any more help just ask.
Here is mine for comparison. (i'm using Fastmame)
### fastmame.ini ###
### Frontend Related ###
clones                  1
### Windows path and directory options ###
rompath                 G:\Mame Plus\roms
samplepath              samples
# inipath               fastmame.ini
cfg_directory           cfg
nvram_directory         nvram
memcard_directory       memcard
input_directory         inp
hiscore_directory       hi
state_directory         sta
artwork_directory       artwork
snapshot_directory      snap
diff_directory          diff
ctrlr_directory         ctrlr
cheat_file              cheat.dat
history_file            history.dat
mameinfo_file           mameinfo.dat
### Windows video options ###
autoframeskip           1
frameskip               0
waitvsync               0
triplebuffer            0
window                  0
ddraw                   1
direct3d                0
hwstretch               1
cleanstretch            auto
resolution              640x480
zoom                    2
refresh                 0
scanlines               0
switchres               1
switchbpp               1
maximize                1
keepaspect              1
matchrefresh            0
syncrefresh             0
throttle                1
full_screen_brightness   0.000000
frames_to_run           0
effect                  none
screen_aspect           4:3
sleep                   1
rdtsc                   0
high_priority           0
### Windows Direct3D 2D video options ###
d3dtexmanage            1
d3dfilter               1
d3dfeedback             0
d3dscan                 100
d3deffectrotate         1
d3dprescale             auto
d3deffect               none
# d3dcustom             <NULL> (not set)
# d3dexpert             <NULL> (not set)
### Windows sound options ###
audio_latency           1
### Input device options ###
mouse                   0
joystick                0
lightgun                0
steadykey               0
keyboard_leds           1
a2d_deadzone            0.300000
# ctrlr                 <NULL> (not set)
### Mame CORE video options ###
norotate                0
ror                     0
rol                     0
autoror                 0
autorol                 0
flipx                   0
flipy                   0
debug_resolution        auto
gamma                   1.000000
brightness              1.000000
pause_brightness        0.650000
### Mame CORE vector game options ###
antialias               1
translucency            1
beam                    1.000000
flicker                 0.000000
intensity               1.500000
### Mame CORE sound options ###
samplerate              44100
samples                 1
resamplefilter          1
sound                   1
volume                  0
### Mame CORE misc options ###
artwork                 1
use_backdrops           1
use_overlays            1
use_bezels              1
artwork_crop            0
artwork_resolution      0
cheat                   0
debug                   0
# playback              <NULL> (not set)
# record                <NULL> (not set)
log                     0
maxlogsize              10000
oslog                   0
skip_disclaimer         1
skip_gameinfo           1
crconly                 0
bios                    default
### Configuration options ###
readconfig              1
verbose                 0
« Last Edit: May 02, 2006, 11:02:51 pm by gonzo90017 »
