Author Topic: Sliver to Dragon's Lair?  (Read 1940 times)
jelwell
  • Last login:December 24, 2014, 03:47:21 pm
« on: April 20, 2006, 06:30:17 pm »
I started off curious to know what Sliver is. The game sounds familiar, but I couldn't find much information on it.
From the whatsnew_0105u2.txt file:
Sliver [David Haywood]
Guru's dump site lists it as a produced by Hollow Corp in 1996. I couldn't find anything in KLOV.
Is it porn? I found this quote that appears to be from Haze back in November 2004:
Quote from: Haze
sliver is one of the most weird pieces of hardware i've encountered .. it has a
dedicated jpeg decompression chip to decompress the pr0n ... not exactly the
easiest hw in the world to emulate .. the rest of it is pretty damn weird too,
never got it to display a thing.
From Guru's site:
Quote from: Guru
Can't remember what this is. Uses a strange MPEG chip which the dev was scared of so it probably won't be in MAME until we get some free MPEG library, or someone writes one.
Now I'm curious. If MAMEdevs add a free MPEG library I wonder if that's a step towards being able to support Dragon's Lair?
Quote from: Haze Retroblast Interview
Well, I've not made it a secret that I'm itching to re-do the video system to rely on the OS-dependent code to mix and render the artwork and video screen. There are a ton of benefits to this. Multi-screen games will be able to run on separate monitors; it will be possible to view just one or all of the screens on a multi-screen game; you'll be able to adjust the video screen much like you can adjust your monitor (stretch/shrink, adjust position); vector games and artwork will run much faster; artwork will be higher quality (running at your native resolution); it will be much easier to add laserdisc games support; etc, etc. It's a big jump, and I've done some preliminary work, but I'm not quite ready to launch into it full speed ahead just yet.
Has it begun?
Joseph Elwell.
jelwell
Re: Sliver to Dragon's Lair?
« Reply #1 on: December 01, 2006, 01:26:37 pm »
Yes, yes it has, from the 110u4 What's new file:
Rewrote the Dragon's Lair driver from the schematics. Added new
module machine/laserdsc.c which has laserdisc emulation for the
PR-7280 and LD-V1000 laserdisc players. Full emulation of the
laserdisc is pending support for CHD audio/video and high quality
rips, but you can operate the game and see the frame numbers that
would be displayed. Added built-in layout to display the scores,
lives, and credit information. [Aaron Giles]
Joseph Elwell.
Organic Jerk
  • Last login:May 09, 2013, 12:39:09 am
  • I'm per pixel lit.
    • OmeshPersaud.com
« Reply #2 on: December 01, 2006, 05:41:52 pm »
Porn makes the world go round it seems.
Progress Rate:  Moderate      ||      Threads:  Cabinet  |  Art  |  MaLa Layout
XBL: OrganicJerk  |  PSN: OrganicJerk
Havok
  • Trade Count: (+17)
« Reply #3 on: December 01, 2006, 05:58:18 pm »
Hopefully he does the video re-write to access OS code - Mame will run waaaaay better!
_Iz-
  • Last login:Today at 12:35:23 am
  • Time to coin up!
« Reply #4 on: December 04, 2006, 07:39:50 pm »
I thought the video rewrite was done a few versions ago (.107?)
