Author Topic: project64 and mamwah  (Read 2056 times)
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
« on: April 19, 2006, 10:54:33 pm »
I Cant get it to work with mamewah can anyone see a mistake in my ini?
unclet
Re: project64 and mamwah
« Reply #1 on: April 19, 2006, 11:16:28 pm »
Maybe you could describe exactly what is not working and what you see when you try to execute a game from MameWah.....
Marky_1979
    • Personal Webspace
« Reply #2 on: April 19, 2006, 11:57:22 pm »
When i  select a rom from my list it goes to load it then says error cannot load file.
unclet
« Reply #3 on: April 20, 2006, 07:06:05 am »
I use MameWah-v1.62b9 so my configuration is a little different than your but should basically be the same settings.  Anyway, here are the differences which I have from you:
1) My N64 games have extension ZIP so I start them using ZIP rather than Z64.  Double-check your rom files have "Z64" extensions rather than "ZIP" files ..... obvious I know, but worth double-checking the obvious sometimes.
2) I do NOT have quotes around the [rompath]\[name].[romext] stuff
3) I am also using the Project64-1.6 command line wrapper from the CPViewer site.
Are you using this wrapper to try to start your games?
Wrappers are located here:
http://www.emuchrist.org/cpviewer/commandlinewrappers.htm
« Last Edit: April 20, 2006, 07:12:33 am by unclet »
Marky_1979
    • Personal Webspace
« Reply #4 on: April 20, 2006, 03:40:51 pm »
im a bit confused mate whats a wrapper and what do i need to do? i think i might need a fresh start wipe everything and start a fresh
Marky_1979
    • Personal Webspace
« Reply #5 on: May 03, 2006, 12:29:05 am »
ah iv looked on that site and see the wrappers you mean where do i put all the stuff?
gonzo90017
« Reply #6 on: May 03, 2006, 01:41:09 am »
Marky_1979
    • Personal Webspace
« Reply #7 on: May 03, 2006, 09:11:43 am »
many thanks mate :) will try it out
