Author Topic: Toshiba PB-6643 question  (Read 1856 times)
jtkauff
  • Last login:July 07, 2006, 05:05:03 am
« on: April 19, 2006, 03:39:55 pm »
I've got a Toshiba PB-6643 monitor in a machine and when testing it, I fear I might have done something stupid. Looking over some info on some various sites, it looks like the Toshiba likely uses a composite positive sync. Unknowingly I hooked up a JAMMA harness to it and spliced the composite negative sync lead from the harness into positive sync of the monitor and let it run a little while (albeit all scrambled looking) without realizing the positive/negative aspect. In doing this did I do anything permanent to the monitor, or should the monitor be fine?
« Last Edit: April 19, 2006, 04:20:07 pm by jtkauff »
grantspain
Re: Toshiba PB-6643 question
« Reply #1 on: April 19, 2006, 05:26:06 pm »
monitor will be fine,don't worry :cheers:
jtkauff
« Reply #2 on: April 19, 2006, 06:44:01 pm »
Good to hear :) Thanks!
