Author Topic: 8liners chassis question  (Read 2084 times)
Wir3d
  • Last login:October 31, 2007, 04:41:45 pm
  • Huh?
« on: April 11, 2006, 11:58:55 pm »
Hi, ive just installed an 8liners chassis to my 25" crt and when i plug it in is it unusual that a high pitch whining noise comes from the back of the arcade?
Ken Layton
  • Guru
  • Technician
Re: 8liners chassis question
« Reply #1 on: April 12, 2006, 12:31:22 am »
First thing to check is make sure the high voltage ("anode") connector under the rubber suction cup is securely fastened. Second thing is check to be sure all wiring is bundled properly & neatly. Third thing to check is if all the electrical and frame grounds are properly connected. Fourth thing is that you may just be hearing the high frequency vibrations of the flyback transformer (some people can and some people can't hear it).
Wir3d
  • Huh?
« Reply #2 on: April 12, 2006, 10:33:35 pm »
ok, problem fixed, now i have another problem...when im viewing the screen the left side and right side of the screen are squished together, but the middle of the screen is stretched out...is there any adjustments i need to know about to fix this?
Wir3d
  • Huh?
« Reply #3 on: April 12, 2006, 10:47:26 pm »
oh, yea and i also have a weird squiggly line theat is barely noticable on the left side of the crt about 2 inches away from the side of the crt....could this be a bad solder joint when i soldered the new RGBY plug to the yoke?
Ken Layton
  • Guru
  • Technician
« Reply #4 on: April 13, 2006, 12:34:56 am »
Sounds like a horizontal linearity adjustment problem.
Wir3d
  • Huh?
« Reply #5 on: April 13, 2006, 01:04:24 am »
is there any way to fix that? and when i play fighting games the fighters are really skinny when they are on the very left or very right of the screen and when there in the middle of the screen there kinda fat, any awnser to this problem?
Ken Layton
  • Guru
  • Technician
« Reply #6 on: April 13, 2006, 01:13:55 am »
Adjust horizontal linearity control and/or horizontal size (a.k.a. width).
Wir3d
  • Huh?
« Reply #7 on: April 13, 2006, 01:26:37 am »
now where would i find this adjustment? on the chassis or is it on the little control panel with the 8 or so adjustments on it?...because ive tried all the adjustments on that little control panel and it doesnt fix anything
PoDunkMoFo
  • Last login:January 09, 2025, 07:20:35 pm
  • If we weren't all crazy we would go insane... JB
    • Visual Horizons
« Reply #8 on: April 14, 2006, 07:57:56 pm »
Sounds like barreling.  I think that is the correct term for what you are describing.  Screen kinda has a barrel shape.  It is the opposite of pincushioning which would be larger on the sides and shrunk in the middle.  I don't remember if there was a cure for this and if so what it was.
Check the comparison page for chassis replacement in the Monitor fax.
