Author Topic: Spyware problem  (Read 1155 times)
USSEnterprise
  • Last login:October 11, 2007, 11:15:08 pm
    • USS Odyssey
Spyware problem
« on: April 11, 2006, 04:40:59 pm »
I apparently have a spyware program on my PC. Its called EbatesMoneyMaker. I keep seeing it in my task manager, and everytime I try to end it, it restarts. Even when I use End It All, it still lives. I've dealt with this program before, but in the past, Spybot was able to remove it. For some reason now, Spybot doesn't see it as being bad. Any suggestions?
Proper capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse.
ha-Y-n
  • Last login:November 29, 2007, 06:16:07 pm
  • Shaka braddah
    • www.brianDAhawaiian.net
Re: Spyware problem
« Reply #1 on: April 11, 2006, 04:53:34 pm »
Try and see if you can uninstall it in add/remove programs
if that doesn't work post a hijack log
zvar
  • Last login:October 08, 2019, 11:39:56 pm
  • One of these days I'll think of somthing cute.
Re: Spyware problem
« Reply #2 on: April 11, 2006, 06:23:06 pm »
Or try Google.
The first few hits seem to be what you need.  If that fails then I'd suggext a hjt log.
Steven
AtomSmasher
    • Atomic-Train
Re: Spyware problem
« Reply #3 on: April 12, 2006, 02:40:54 am »
See if adaware will get it  http://www.lavasoft.de/software/adaware/   I use both adaware and spybot because neither get everything.
RayB
  • I'm not wearing pants! HA!
  • Last login:July 10, 2025, 01:33:58 am
  • There's my post
    • RayB.com
Re: Spyware problem
« Reply #4 on: April 12, 2006, 01:43:42 pm »
I second the motion to always use both.
Also, check your start-up config and see if anything related to it is in there.
(Click START, select RUN, type "msconfig")
If so, disable the entry, and restart the computer. Hopefully it won't start the adware. Then you should have better luck removing it.
NO MORE!!
Dartful Dodger
  • Newer isn't always better.
Re: Spyware problem
« Reply #5 on: April 12, 2006, 04:51:24 pm »
Your prayers hYour prayers have been answered by the great Bill himself:
Windows security updates now available
