Author Topic: WG 1709154 Arcade VGA compatability  (Read 2049 times)
yugffuts
  • Last login:August 19, 2011, 01:22:57 pm
« on: April 10, 2006, 09:17:21 pm »
Sorry if this has been covered, but a search turned up nothing.
In order to use an ArcadeVGA card with a WG 1709154 monitor, will I need the video amplifier offered by Ultimarc?  Or should I be able to just hook it in with the card via breakout cable directly?
Thanks a lot.
Ken Layton
  • Guru
  • Technician
Re: WG 1709154 Arcade VGA compatability
« Reply #1 on: April 11, 2006, 01:30:42 am »
That Wells-Gardner number you mentioned is only a serial number of the umpteen billion different monitor models that they manufacture. What is the model number?
yugffuts
« Reply #2 on: April 11, 2006, 07:58:58 am »
Damn.  How does model number 25K7191 sound?
Ken Layton
  • Guru
  • Technician
« Reply #3 on: April 11, 2006, 10:26:30 am »
Now that's more like it. 25", k7000 series, standard resolution, isolation transformer required.
yugffuts
« Reply #4 on: April 11, 2006, 11:45:09 am »
Monitor was working fine in an NBA Jam (converted) cab, want to MAME it.  It will recieve it's power from the original power supply, just want to send video from the PC.
Ultimarc's site says
Quote from: Ultimarc
All VGA cards (including our ArcadeVGA card) produce a RGB signal level of 1 volt. Game boards use a level of 5 volts. But Wells-Gardner and Hantarex (and many other) monitors are specc-ed to accept 1 volt or 5 volts (Hantarex have a switch, W-G have a pot). So for these monitors you can make your own cable or use our pre-stripped and labelled VGA breakout cable.
So, do I need the amplifier board for this model monitor, or should I be able to adjust the pot?  I want to avoid ordering and recieving the AVGA, realizing I need the amplifier board, and re-ordering, re-paying shipping, and re-waiting for the part.
Anyone know if I need the amp or not?
Ken Layton
  • Guru
  • Technician
« Reply #5 on: April 11, 2006, 06:28:42 pm »
I believe this model requires an amplifier.
