Author Topic: Hantarex monitor picky about input signals (sync problem?)  (Read 3581 times)
dennis808
  • Last login:May 13, 2021, 08:40:00 am
  • Holy Sanwa-sticks!
« on: April 10, 2006, 10:42:06 am »
Im trying to hook up a Hanterex MTC21EQ monitor to some of my consoles (PlayStation2, Dreamcast).
I believe this is a type of monitor that is being used in surveillance, editing, or point-of-purchase environments, since it sports a wealth of options on the back as you can see in this pic:
and a close-up:
I mainly bought this monitor to replace the old Mitsubishi TV which I have in my cabinet right now.
Here's a pic of the Mitsubishi TV hooked up to a Dreamcast with a RGB-SCART cable:
Since the Hantarex also has a SCART socket (which accepts RGB signal) I thought it would be an easy swap. But the only picture I'm getting (even after adjusting all of the pots) is this:
really sharp, but completely scrambled  :(
Both the Dreamcast and the Playstation2 give these type of images when I connect them via RGB-SCART cables.
When I connect the consoles via composite (the yellow RCA plug) I get a stable image, but without the nice quality of an RGB connection:
What REALLY confuses me is that when I hook up my DVD-player via RGB-SCART, it gives me a stable and clear picture  ???
Is this a sync issue? And if so, why is my DVD-player's image visible while it's outputting the same type of signal?
Please someone help me so I can use this Hantarex in it's full RGB glory...
« Last Edit: August 05, 2009, 08:59:22 am by dennis808 »
"Complexity is the process by which the obvious is obscured by the irrelevant." -HSW
grantspain
Re: Hantarex monitor picky about input signals (sync problem?)
« Reply #1 on: April 10, 2006, 02:20:44 pm »
try tweeking your hor phase pot next to the scart,its possible the frequency is slightly different
dennis808
« Reply #2 on: April 10, 2006, 04:55:35 pm »
I tried adjusting the Hor Phase, but it only made the bars move a little bit slower or faster.
When I change the priority switch, I can see flashes of sharp and stable images, so it must definitely be possible to display a proper image.
« Last Edit: February 15, 2010, 05:19:52 am by dennis808 »
grantspain
« Reply #3 on: April 10, 2006, 05:42:27 pm »
thats def sinc problem,maybe its a bad scart lead or dry joints on the socket.whats that 75 ohms switch do when you press it?
dennis808
« Reply #4 on: April 10, 2006, 07:52:41 pm »
The strange thing is, that both consoles are working when using the SCART input on the TV that's in the cab.
And the DVD-players works correctly when connected via RGB-SCARt on the Hantarex.
The 75Ohm button gives a little jump in the picture when I push it, but no change.
Could the sync signal coming from the consoles be too weak?
grantspain
« Reply #5 on: April 11, 2006, 11:51:36 am »
obviously you have checked those other two buttons,sinc and analogue
conkerkrusher
  • Last login:July 25, 2006, 05:38:00 pm
« Reply #6 on: April 11, 2006, 01:42:47 pm »
dvd player is running progressive scan correct? the ps2 isnt and niether is the dreamcast.
dennis808
« Reply #7 on: April 14, 2006, 04:11:33 pm »
I really doubt that my (cheap) Samsung DVD-player outputs a progressive signal, since it is normally hooked up to a non-progressive TV.
I have one PS2 game that can be set to progressisve output, so I will surely try that ASAP.
sav1
  • Newbie
  • Last login:June 15, 2012, 07:01:16 am
« Reply #8 on: August 09, 2006, 10:19:21 pm »
dennis,
that the same hantarex monitor i have. when i first hooked up my pc with a arcadevga and homemade vga to scart it gave the exact same picture.
i went to this link which shows the hantarex pinouts : http://www.hantarex.com/pdf/MGGEQ3.pdf
I had originally copied a vga to scart cable from the net. It used a composite sinc which the hantarex does'nt accept. the hantarex needs a seperate horizontal and vertical sync. (pins 10 and 12). I assume that is what the "HV" stands for in the "Analog RGB-HV" above the scart connector on the back of your monitor.
once i rewired the H and V syncs from the vga to the scart the picture was perfect.
I would say your dvd player outputs the syncs seperately thats why it works.
cheers,
sav
« Last Edit: August 09, 2006, 10:23:05 pm by sav1 »
dennis808
« Reply #9 on: August 10, 2006, 04:23:40 am »
WOW! I never expected any more replies on this post. Thanks a bunch for your reply!
Sounds like a really viable solution.
The only caveat is that next to the PC I also have a Dreamcast and a PS2 in my cab that I would like to hook up via RGB-Scart. Is there a way to make those machines send out separate H+V sync?
