Author Topic: Keywiz Uploader run hidden?  (Read 1942 times)
Havok
  • Trade Count: (+17)
« on: April 09, 2006, 07:37:40 pm »
After extensive searching, I cannot find any info on this, so here I go.
Is there a way to run the Keywiz uploader software completely hidden? I have it working with the /A switch, which is cool - I do like the laser beams while programming, but would like to hide everything on boot.
Is there a way to do this?
whatisk
  • Last login:March 27, 2017, 06:41:39 am
  • Nothing to see here
Re: Keywiz Uploader run hidden?
« Reply #1 on: April 09, 2006, 10:23:18 pm »
There is, as on my cab there is just a small dot in the upper left hand corner when uploading my custom key set.
When I get home, I'll check it out on my cab and post back here. I think it may even be a seperate app that you need to do it.
No trees were harmed in the creation of this post. Though several electrons were severely inconvenienced.
chemame
  • Last login:January 26, 2007, 01:54:05 pm
« Reply #2 on: April 10, 2006, 06:55:59 am »
I have what I think is the KeyWiz silent uploader. I say "I think" because, though I've had it for over a year, I've never tested it. Beat THAT amount of procrastination, I say!
http://www.crazybaldman.com/stuff/KWstealth.zip
Havok
« Reply #3 on: April 10, 2006, 08:53:48 am »
Thanks - I'll check it out when I get home and report back. Or, maybe I'll wait a year...
whatisk
« Reply #4 on: April 10, 2006, 06:13:31 pm »
Yep, that's what I use (after checking on my cab). I think I got it specifically off RandyT a while back as it isn't on the GroovyGameGear website.
The line I run is like this:
Code: [Select]
c:\keywiz\kwstealth.exe /a /p cThe '/p c' just tells it to load my keyset 'c'.
Havok
« Reply #5 on: April 10, 2006, 11:39:12 pm »
That was it! Thanks guys!
Hey Randy - this should be available as a switch for your standard uploader program, or made available on your site...
