Author Topic: Billabs BL27CB0P factory menu?  (Read 2282 times)
conkerkrusher
  • Last login:July 25, 2006, 05:38:00 pm
« on: April 07, 2006, 11:07:06 pm »
Does anyone know how to get into this, the rgb settings are waaaaaay to high when running the PS2 on it.
Atomiswave
  • Last login:June 26, 2006, 01:19:02 pm
Re: Billabs BL27CB0P factory menu?
« Reply #1 on: April 08, 2006, 02:56:46 am »
Perhaps some potentiometers to the RGB wires could do the job
StephenH
« Reply #2 on: April 08, 2006, 03:55:53 am »
Perhaps the PS2 is outputing a 5V signal when your monitor is wanting a 1V signal?
mairsil
  • Last login:June 08, 2017, 11:48:20 pm
    • PouncingKitten Games
« Reply #3 on: April 08, 2006, 05:25:04 am »
Personally, I would like to fix some nasty bowing in one of my corners. I can live with it right now, but I would rather fix it.
Xbox 360 - Glide, Bingo Party, Poker Night
Flash - BunnyRun
Atomiswave
« Reply #4 on: April 08, 2006, 05:27:30 am »
Ask Wei Ya if they could apply a fix for these annoying bowings. I would. Billabs doesn
conkerkrusher
« Reply #5 on: April 08, 2006, 05:47:05 am »
I think this is the case, though i have no idea how to fix this issue.
BTW if anyone else want to hook up thier ps2 to this monitor here are the hookups for the ultimarc adapter.
the connection in red is how to do it. Though the issue now is that it is putting out too much signal.
anyone want to educate me on how i could fix this?
Billabs guys arnt that bad, here is the info they sent me that at least got me a picture
CGA is tricky in that it could be separate sync instead of composite sync.
Does your system have a R,G, B, Gnd, H-sync, V-sync?
If so, we'll do the following: first let's define the wires from your system.
Use Gnd, H-sync, V-sync for signal output wires from your system, and
gnd, h-sync, v-sync for monitor input wires.  The RGB wires stay with rgb monitor wires.
You need to try any of the combinations below:
Gnd to gnd, V-sync to v-sync (leave h-sync unhooked).
Gnd to gnd, H-sync to v-sync (leave h-sync unhooked)
Gnd to gnd, V-sync+H-sync to v-sync (leave h-sync unhooked)
Gnd to v-sync+h-sync, H-sync+V-sync to gnd.
so on and so forth...
Chances are your system has separate video outputs and they are of reverse polarity.
You have basically 3 wires from your system (unknown) that need to connect properly
to the 3 wires from the monitor.  There are 3! combinations here.
Be sure to turn off the monitor each time you try something.  The picture should either
show up, or turn it off, and try another combination.
Be safe!
Ben
Billabs Tech Support
BILLABS Manufacturing
Manufacturer of Amusement Products and Gaming Devices
Industrial monitors, power supplies, commercial speakers
mamerocks87
  • Last login:March 17, 2007, 12:21:33 pm
« Reply #6 on: April 09, 2006, 10:34:14 pm »
there has been bowing problems on these billabs multisyncs?
