Author Topic: H and V synch on a 25" Nanao MS8-26SU  (Read 3621 times)
RetroJames
  • Last login:December 10, 2021, 05:26:38 pm
« on: March 16, 2006, 02:03:04 pm »
I have this 25" Nanao MS8-26SU monitor I am attempting to use in a new MAME cabinet and planned to use it with an Act Labs lightgun with an ArcadeVGA.
I just saw this note on Andy's site -
The Act-Labs USB gun works but there are some factors to bear in mind. The
gun will only work if the H and V sync are not connected together. The H and
V signals must both be connected to the monitor.
The connector I have uses 5 of the 6 pins in the connector as follows:
R
G
B
GND
Synch (H and V)
Looking on the chassis, see attached, I see 6 pins but it is unclear if the 6th can be used in such a way that would "split" the synchs
R
G
B
GND
H or V synch
V or H synch
I need to find out if the synch can or is split between these pins so the act labs gun will work.
Finding a Nanao schematic or manual is near impossible and I am hoping someone here has the answer. Thanks in advance for any assitance you can provide!
Orclord
  • Last login:October 16, 2009, 03:09:38 pm
Re: H and V synch on a 25" Nanao MS8-26SU
« Reply #1 on: March 16, 2006, 03:47:35 pm »
Well this might not help a lot.....
I have a Nanao MS9-29SU...Manufactured in 96....Just taken the back off the cab and that connector on mine is R-G-B-GND-H-V...I only have 5 wires connected as well.
I tried to get a photo but it's too dark and I thought waving my camera around in the back was not a good idea...seeing as the lens cap snagged on a few cables....
The schematics I have are not for this monitor
RetroJames
« Reply #2 on: March 17, 2006, 07:21:14 am »
I guess I may need to look on the underside of the chassis PCB.
grantspain
« Reply #3 on: March 17, 2006, 04:17:26 pm »
My take on this issue is you only have one sinc input so you can't attach two seperate sincs,but why does that light gun require both sincs connected-i mean my arcade has many gun games which only have one sinc connected,is there something different about the act labs gun that it uses both sincs as its trace
RetroJames
« Reply #4 on: March 20, 2006, 07:12:41 am »
Not sure, it may be a requirement of the ArcadeVGA, not the gun.  Anyway, here is the answer from Jomac in Au. I am told he is the go-to-guy for Nanao monitors and he came through here:
"Hi James ,
The Comp H-Sync input on the chassis means it will accept a signal from a
game that is producing a composite negative sync , if however you are not
supplying this pin with a composite sync you need to also connect the V-sync
pin .
Basically Composite is a combination of the V and H , but as you are not
going to be supplying the chassis with a combination you can use the H and V
pins separately as you need without any modification to the chassis.
Just remember the both V and H and Negative Sync
1:Red
2:Green
3:Blue
4:Gnd
5 H Sync
6 V Sync
Let me know if this works ok for you James ,
Regards,
Joe McNicol ( Jomac )"
http://www.jomac.net.au
