Author Topic: How do I exit Mamewah using Alt+F4?  (Read 2041 times)
gonzo90017
« on: March 11, 2006, 12:29:26 am »
How  can I do this?
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
Re: How do I exit Mamewah using Alt+F4?
« Reply #1 on: March 11, 2006, 12:34:03 am »
Press Alt+F4 ;D
gonzo90017
« Reply #2 on: March 11, 2006, 01:20:06 am »
Doesn't work. I know I have to edit default.ini in the ctrlr folder but I have no idea how to put it?
# MAMEWAH 1.6+ Standard Control Configuration
# PLEASE USE INPUT CODES FROM \MAMEWAH\DOCS\CTRLR.TXT
# NOTE DIFFERENCES TO MAME's (EX!) CTRLR INI FILES:
# 'NOT' (!) LOGIC NOT SUPPORTED
# 'AND' LOGIC EXPRESSED USING '&' (NOT SPACE)
# 'OR' PIPE '
unclet
« Reply #3 on: March 11, 2006, 06:23:38 am »
Seems like making the following change would work:
EXIT_TO_WINDOWS            "DIK_LALT & DIK_F"
If you wanted to exit using ESC as well as Alt-F4, then this works for me:
EXIT_TO_WINDOWS            "DIK_ESCAPE | DIK_LALT & DIK_F"
« Last Edit: March 11, 2006, 06:26:53 am by unclet »
jcrouse
    • CPViewer
« Reply #4 on: March 11, 2006, 10:17:04 am »
you forgot thre F4 (you just used F). It is probably something like so:
"DIK_LALT & DIK_F4"
John
gonzo90017
« Reply #5 on: March 11, 2006, 01:45:14 pm »
Just tried it and it doesn't work ??? EXIT_TO_WINDOWS         "DIK_ESCAPE | DIK_LALT & DIK_F4" When I press Esc it works but when I try Alt+F4 nothing happens. Am I missing something?
jcrouse
    • CPViewer
« Reply #6 on: March 11, 2006, 02:20:40 pm »
Works for me. I just tried it! Are you using the DIK_LALT or DIK_F4 for something else? Just a thought.
John
gonzo90017
« Reply #7 on: March 11, 2006, 11:27:53 pm »
Thank you for your help guys. ;D You were right jcrouse I had never changed anything but by default DIK_LALT was being used for PREVIOUS_TRACK and LAUNCH_GAME_WITH_OPTIONS2. Just deleted both and it now works. Thank you all once again.
