Author Topic: my mk2 monitor only shows red  (Read 1702 times)
mvarady
  • Last login:May 09, 2007, 10:28:56 pm
« on: March 04, 2006, 06:45:20 pm »
Scored a free mk2 the other day and the monitor only shows red.The color is way out of wack.I looked for green and blue adjustments and did not find them.need advice.
SirPeale
  • Green Mountain Man
Re: my mk2 monitor only shows red
« Reply #1 on: March 04, 2006, 08:07:44 pm »
1) didn't state the make/model of monitor
2) did you check the connections to make sure everything is plugged in?
mvarady
« Reply #2 on: March 04, 2006, 10:58:25 pm »
25 inch wells-gardner 25k-7197.i can't find any red-green-blue knobs.it's driving me crazy.At first all i saw was rainbow colors on the edges.I degaussed the monitor and the rainbow left.The only colors are red.If a connector is loose,where should i look???Thanks!!!!!!!!!!!!!
grantspain
« Reply #3 on: March 05, 2006, 04:46:59 pm »
if you have a red screen with diagonal lines going across it then your red drive transistor is short circuit,i think you can find your colour controls on the neck card-but its been a long time since i worked on this type chassis so no doubt someone else on this forum will put me right.you see what you need to prove is
1-is your red transistor driving short
2-are your green and blue not adjusted correctly
3-are your colour inputs from your game board present
mvarady
« Reply #4 on: March 05, 2006, 08:38:14 pm »
No red lines.I can't even find the blue and green color adjusters.further inspection looks like the monitor is a replacement one.Uncovered some dust and found Phillips w22x model.
« Last Edit: March 05, 2006, 10:19:38 pm by mvarady »
Q*Bert_OP
  • Oh yes, we did!
« Reply #5 on: March 06, 2006, 10:05:03 pm »
Heater-Cathode short?
Try tapping on the clear glass neck of the tube, very gently, with the handle of a screwdriver, while the monitor is off...
