Author Topic: Odd problem could be mamewah, jpac or both  (Read 1430 times)
menace
« on: March 03, 2006, 09:23:51 am »
I'm running standard mame .72 with a Jpac and Mamewah 1.61.  The weird behaviour is that when button 3 is hit and a the joystick moves right--it activates a pause, button 3 + left is coin up.  I can't find anything in my default controller INI that would explain this and the Jpac is set to default (i.e. player 1 is the shift button not button 3)  Any thoughts?  I've attached the mamewah control ini for reference cause I did make some changes in there.
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: Odd problem could be mamewah, jpac or both
« Reply #1 on: March 03, 2006, 09:31:41 am »
did you test your jpac in test mode?
Try to under dos. (or boot command line version).
on the dos prompt : press CTRL + ALT + P
The JPAC shoud go in test mode.  Try to move your joystic , button etc...  and check output on the screen to see if it matches with that you expect.
(i think it works from the notepad too , but not sure, i never tried).
menace
« Reply #2 on: March 03, 2006, 09:57:01 am »
Ok I reset the Jpac and it seems to have cured itself--weird.  thx all the same!
