Author Topic: ArcadeVGA install help please  (Read 2395 times)
mattudland
  • Last login:September 29, 2012, 08:17:57 am
  • Official Arcade Controls Opera Singer
« on: February 17, 2003, 10:44:28 pm »
Hello ArcadeControls Board Masterminds,
I posted this message over at ULTIMARC, but the board over there is usually slower then this one, so I thought I'd see if anybody here had an answer for me.
So I finally got around to trying to install the arcadevga tonight. I am running a crappy old P3 450 Windows XP System. It is a Dell motherboard, that has no onboard video. So, when I install this card I have to take my other card out and put it in the 1 AGP slot.
However, no matter which of the two ports I plug my monitor into, I get a screen of seriously wavvy lines, I can't make out anything but basic colors of my computer starting up. When Windows XP finally loads, the screen turns blue (I'm assuming blue screen of death) and restarts.
So, even if I run in safe mode, I have to plug the arcade VGA in prior to turning on the PC, and no matter what I always get these wavy lines. How can I get the monitor to view this? Do I need to plug it into my arcade monitor and use that to install the arcadevga?
Please let me know what your thoughts are.
Thanks a lot,
Matt
Of course that's just my opinion, I could be wrong.
OSCAR
    • Oscar Controls
Re:ArcadeVGA install help please
« Reply #1 on: February 17, 2003, 11:04:08 pm »
Install the Windows drivers with the arcade monitor connected.  Your PC monitor most likely cannot handle the 15KHz signal the card produces, which is why you aren't getting a proper display during bootup.  From the info here, http://www.ultimarc.com/avgainst.html, it implies that the secondary port will only work in SVGA mode after you have the ATI drivers installed.
« Last Edit: February 17, 2003, 11:25:21 pm by OSCAR »
mattudland
« Reply #2 on: February 19, 2003, 02:45:37 am »
Thanks for the advice...  here is my new dilemma.
I'm currently running the setup through windows Mame32, the GUI version right?  Anyway, when I'm in windows the screen is super clear.
When I get to games, the picture bounces, slightly, so all the text looks more blurry than it should.
Also, when I load a game like Mortal Kombat, the screen cuts off about 1/4 of the bottom of the screen.  Is there some configuration step I'm missing?
Thanks for the advice,
Matt
tom61
  • Last login:September 18, 2017, 12:46:56 am
« Reply #3 on: February 19, 2003, 04:42:38 pm »
Make sure you turned off hardware stretching in the Mame32 options. If that doesn't help, you may have to adjust your arcade monitor.
