Author Topic: Monitor power question  (Read 1276 times)
mjc0505
  • Last login:July 16, 2007, 10:02:11 am
« on: February 15, 2006, 11:59:33 am »
I have searched and read and seen the basic ac wiring diagram, but I want to make sure I'm right before I carve this up and plug it in.  This was/is a generic Dynamo HS-9 cabinet that had a Neo Geo game in it with a WG 25K7193 monitor.
The isolation transformer and the power supply both are coming off the same external outlet, so can I just cut the wires going to the power supply and leave the isolation transformer attached (I'd like to leave the box in there, because it fills a huge hole on the back of the cabinet)?
Alternatively, I thought about cutting the plug off of a surge protector and connecting it to that external plug and then using then plug I cut off the surge protector to attach to the isolation trasnformer wire and then plug it into the strip along with the computer, lights, etc.  That way I would still only have the one plug coming out of the back.  Is this dangerous/feasible?
Lastly, what is that thing underneath and to the right of the isolation transformer and can I leave it alone without consequence?
Thanks for any help.
grantspain
  • Last login:July 25, 2025, 09:21:43 am
Re: Monitor power question
« Reply #1 on: February 15, 2006, 05:01:30 pm »
that box under the transformer looks like a ballast of some kind,but you need to follow the wires to see what it powers
