Author Topic: Auto frameskip not working in MAMEWAH using fastmame 71  (Read 1342 times)
gonzo90017
« on: February 13, 2006, 05:46:10 pm »
What am I doing wrong. Frame skipping works when i'm running Mame32v 55 using MAMEWah but when I use FastMame v71 it doesn't work even though I set autoframeskip to ! in the ini file. Planning to build a bartop and pressing F10 wont be an option. Well here it is.
### fastmame.ini ###
### Frontend Related ###
clones                  0
### Windows path and directory options ###
rompath                 roms
samplepath              samples
# inipath               <NULL> (not set)
cfg_directory           cfg
nvram_directory         nvram
memcard_directory       memcard
input_directory         inp
hiscore_directory       hi
state_directory         sta
artwork_directory       artwork
snapshot_directory      snap
diff_directory          diff
ctrlr_directory         ctrlr
cheat_file              cheat.dat
history_file            history.dat
mameinfo_file           mameinfo.dat
### Windows video options ###
autoframeskip           1
frameskip               0
waitvsync               0
triplebuffer            0
window                  0
ddraw                   0
direct3d                1
hwstretch               1
cleanstretch            none
resolution              640x480
zoom                    2
refresh                 0
scanlines               0
switchres               1
switchbpp               1
maximize                1
keepaspect              1
matchrefresh            0
syncrefresh             0
throttle                0
full_screen_brightness   0.000000
frames_to_run           0
effect                  none
screen_aspect           4:3
sleep                   1
rdtsc                   0
high_priority           1
### Windows Direct3D 2D video options ###
d3dtexmanage            0
d3dfilter               1
d3dfeedback             0
d3dscan                 100
d3deffectrotate         1
d3dprescale             auto
d3deffect               none
# d3dcustom             <NULL> (not set)
# d3dexpert             <NULL> (not set)
### Windows sound options ###
audio_latency           1
### Input device options ###
mouse                   0
joystick                0
lightgun                0
steadykey               0
keyboard_leds           0
a2d_deadzone            0.300000
# ctrlr                 <NULL> (not set)
### Mame CORE video options ###
norotate                0
ror                     0
rol                     0
autoror                 0
autorol                 0
flipx                   0
flipy                   0
debug_resolution        auto
gamma                   1.000000
brightness              1.000000
pause_brightness        0.650000
### Mame CORE vector game options ###
antialias               1
translucency            1
beam                    1.000000
flicker                 0.000000
intensity               1.500000
### Mame CORE sound options ###
samplerate              44100
samples                 1
resamplefilter          0
sound                   1
volume                  0
### Mame CORE misc options ###
artwork                 0
use_backdrops           0
use_overlays            0
use_bezels              0
artwork_crop            0
artwork_resolution      0
cheat                   0
debug                   0
# playback              <NULL> (not set)
# record                <NULL> (not set)
log                     0
maxlogsize              10000
oslog                   0
skip_disclaimer         1
skip_gameinfo           1
crconly                 0
bios                    default
### Configuration options ###
readconfig              1
verbose                 0
gonzo90017
Re: Auto frameskip not working in MAMEWAH using fastmame 71
« Reply #1 on: February 13, 2006, 11:03:35 pm »
Nevermind :D Set Throttle to 1. But it seems to decrease the FPS.
« Reply #2 on: February 14, 2006, 05:32:08 am »
It should do...unthrottled usually sends the FPS sky high.
