Author Topic: Tube need rejuivinated...  (Read 2706 times)
mamerocks87
  • Last login:March 17, 2007, 12:21:33 pm
« on: February 03, 2006, 10:24:08 am »
My tube in my monitor needs rejuvinated, and i was wondering where i could get this done at and how much would a descent price be to get it done (dont want to get screwed...) Also would it be cheaper just to get a new tube instead of getting the old one up and full power again?
-kyle
Ken Layton
  • Guru
  • Technician
Re: Tube need rejuivinated...
« Reply #1 on: February 03, 2006, 10:52:06 am »
Most tv repair shops can do it, but I telephone around first though. Ask if they can do picture tube rejuvenation, and if so, what do they charge? Usually the average charge is $50 to as high as $100.
mamerocks87
« Reply #2 on: February 03, 2006, 12:44:08 pm »
do new tubes come charged? how much is a new tube and how hard would it be to install
Ken Layton
  • Guru
  • Technician
« Reply #3 on: February 03, 2006, 01:12:16 pm »
Cost of a new tube depends on the size, manufacturer, and shipping costs. In general, a new 19" tube sells for around $125 to $150 just for the tube. A 25" tube sells for $175 to $250.
All tube convergence must be re-performed as you must transfer the frame ground strap wiring, degausser coil, yoke, and convergence ring manets over to the new tube. Then everything must be re-aligned.
Q*Bert_OP
  • Oh yes, we did!
« Reply #4 on: February 03, 2006, 02:05:22 pm »
It's a real pain in the a** to converge the picture perfectly :-\
mamerocks87
« Reply #5 on: February 04, 2006, 12:07:40 am »
doesnt sound like much fun. i will call around and see what some prices are. thanks guys,
-kyle
censei
  • Last login:November 05, 2009, 11:02:35 pm
« Reply #6 on: February 04, 2006, 05:11:41 am »
don't waste your money trying to rejuivinate a tube, that $50-$100 dollars can go towards a new monitor. Once you rejuivinate a tube it usually dies in about 6-8 months.
glitch77
  • Last login:March 15, 2017, 09:25:48 pm
  • Pro Gear Spec!
    • My Hyper NeoGeo 64 Site.
« Reply #7 on: February 04, 2006, 09:21:45 am »
Buying a new tube (for a general purpos monitor, other specific monitors are more expensive) these days is just silly. Buying a tube for 100+ is nuts when a brand new full 19" monitor is 155 from happ.
SirPeale
  • Green Mountain Man
« Reply #8 on: February 04, 2006, 09:25:37 am »
Really?  I've seen data that says otherwise.  And Ken says you can get another couple years (on the street) from a rejuve tube.  For home use I imagine it's much more.
mamerocks87
« Reply #9 on: February 06, 2006, 10:34:24 am »
i have a 27" in my cab though so....
censei
« Reply #10 on: February 07, 2006, 03:14:02 am »
like wise rejuivination is not a permit fix and overall is not worth the money in today's market in my opinion, unless you got a rejuivinater to do it yourself. 6-8 months is when a monitor starts to die (noticeable change in picture quality) with daily use . If someone plans to use it once a week, I say "go rejuivinate it" but after sometime, you'll just see the problem reoccur.
Ken Layton
  • Guru
  • Technician
« Reply #11 on: February 07, 2006, 11:09:34 am »
There's also an old rule-of-thumb: "The bigger the picture tube, the faster it dies".
I had an old Sony Trinitron tv set I bought new in 1973 and was used daily. I rejuvenated it twice over it's lifetime and got 30 years out of the set before the tube finally went. Rejuvenation done properly can make the tube last a long time, but every tube reacts differently. Some may last years while others may last 30 seconds.
