Author Topic: video amp required for new monitor  (Read 1458 times)
skeighter
  • Last login:July 19, 2006, 10:42:37 pm
« on: January 18, 2006, 01:11:01 pm »
Just got a new Happs Vision Pro CGA monitor.  I had an old Electrohome G07 hooked up to a ArcadeVGA with a video amp in between.  My question is whether I can just hook the monitor up to the video amp or do I need to remove it and make a breakout cable?  Using the amp would be easiest (only have to connect the wires to the new monitor), but I don't wanna fry anything.  The new monitor says it accepts 0 to 2.4 volts on the RGB and the amp is supposed to output at 5 volts.  Any help will be greatly appreciated.
dhansen
  • Last login:November 28, 2025, 10:41:14 am
  • No Quarters Needed
    • Arcade Stupidity
Re: video amp required for new monitor
« Reply #1 on: January 31, 2006, 05:45:21 pm »
You shouldn't need the video amp for this monitor.  I replaced my Electrohome with a Vision Pro and it was plenty bright without the amp...even through tinted glass.
Doug
..as his cold lifeless fingers lie motionless on the garage floor, all he could hear in his head was...I JUST WANTED TO PLAY A GAME OF DONKEY KONG!!
