Author Topic: Help with games ex thanks  (Read 1294 times)
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
« on: January 13, 2006, 11:32:09 am »
Hello, great frontend i was just wondering if i could get a bit of help to finish my setup...
1. I have a slikstik quad 4, could i please get some instructions on where to put my config file, i looked last night & im not quite sure where to place the folder
2. I assume to change the theme you do this thru displays i have not gotten this far.
I ready to finish the mame section & start daphne, also need to get rid of the nag screen
thanks
divemaster127
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
Goz
  • KOTA
Re: Help with games ex thanks
« Reply #1 on: January 13, 2006, 07:03:36 pm »
Hope this helps
1. You shouldn't need to place a config file anywhere unless you are referring to something you customized out of the slik stik std. Fire up the configuration app. Start --> programs ---> GameEx ---> Configuration and click on the INPUT button on the left. Once this opens there is a clickable drop down for enable slik stik / IPAC support. Select  Yes and hit Save at the bottom of the screen.
2. To change themes open the configuration app mentioned above and click on the DISPLAY button thing on the left and the first item on the page will be THEME. Select from the list. If you have a new theme that you downloaded separate from the install then place the extracted folder in the c:\program files\gameex\themes directory and the next time you start up the configuration application it will show up in the list of themes.
-Goz
divemaster127
« Reply #2 on: January 14, 2006, 12:00:49 am »
Ok, thanks for the help, i got the theme working no problem & i also enabled slikstik support, my player 2 is perfect but player 1 does not work right, i have to use the trackball buttons, i just have a standard slikstik quad 4, i saw a note from tom that he told someone to go into controllers tab & under the 'default input layer' choose x-arcade, i thought maybe i could go into this area & choose slikstik & maybe this work fix my issue, thanks for help
divemaster127
