Author Topic: control panel interface question  (Read 1686 times)
vandel98
  • Last login:January 13, 2006, 11:40:46 am
« on: January 13, 2006, 09:48:10 am »
I'm in the process of planning/purchasing for my first cab.  My question comes in on the best way to interface the components I have already.
3 Happ Joysticks & 18 buttons (2 8 way and 1 4 way joystick)
1 3" Betson Imperial Trackball PS/2
I was looking at the new Cyclone Spinner which says it interfaces with the optipac
http://www.arcadegames4u.com/pc-50-48-cyclone-spinner.aspx
Normally I've read that folks will use the optipac for the spinner and the trackball, but this trackball is PS/2.  I've got the IPAC2 for the joysticks and buttons.
Any thoughts on how I should interface this all together.  Should I still use an optipac, go with a minipac.  So many options and so much confusion.
Thanks,
Pete
ahofle
    • Arcade Ambience Project
Re: control panel interface question
« Reply #1 on: January 13, 2006, 10:58:50 am »
You could go with the Ipac2 for the buttons and sticks and use Randy's new spinner/trackball interface for the spinner (it's cheaper):
http://forum.arcadecontrols.com/index.php?topic=47866.0
vandel98
« Reply #2 on: January 13, 2006, 11:06:07 am »
Does it have an input for my PS/2 trackball?  For that matter Does the optipac?
jjd
  • Last login:June 17, 2025, 10:56:21 am
« Reply #3 on: January 13, 2006, 11:08:57 am »
Did you try plugging the PS/2 plug into your PC to see if it works without another interface board?
I love deadlines. I like the whooshing sound they make as they fly by.
- Douglas Adams
ahofle
« Reply #4 on: January 13, 2006, 11:14:32 am »
vandel98
« Reply #5 on: January 13, 2006, 11:20:43 am »
Is windows smart enough to switch between the trackball connected to the mouse ps/2 port and the spinner if it is using USB or should they share an interface?  The ipac2 will also be USB.
ahofle
« Reply #6 on: January 13, 2006, 11:39:11 am »
You can test that out by hooking up a PS/2 mouse (or your trackball) to a PC, then hook up a USB mouse.  They should both move the cursor.
