Author Topic: Joust/ defender. D9200 flashing  (Read 1495 times)
Bones
  • [Moderator]
« on: January 02, 2006, 05:41:52 am »
I have an identical problem with Joust & Defender on a D9200 running ArcadeVGA. I get a flashing black screen every couple of seconds that begins the moment the rom is launched, and continues throughout game play.
I am using Mame 0.102 and GameEX.
These are the only two roms I have problems with so far. Using a PC monitor I have confirmed everything works fine. Coincidentally (maybe......?), both games have the same Williams boot-up screen although I did notice they are different resolutions.
Been banging my head for a couple of hours and tried quite a few defender.ini video settings but nothing help. Any idea?
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
Re: Joust/ defender. D9200 flashing
« Reply #1 on: January 02, 2006, 11:33:51 am »
Bones:
Try Robotron, Stargate, and Bubbles to see if they exhibit the same behavior.  All of those Williams games ran on the same hardware.
Bones
  • [Moderator]
« Reply #2 on: January 03, 2006, 05:30:17 am »
Yep. They all fail to run properly. Same symptoms.
markrvp
  • NFL Expert
« Reply #3 on: January 04, 2006, 12:29:52 pm »
Bones:
I'm running a Betson Multisync with AVGA.  All the Williams games run fine.  I checked Joust and it is set at 288x240 I think.  Have you changed the refresh rate and forced it to 60Hz?
Bones
  • [Moderator]
« Reply #4 on: January 05, 2006, 06:39:44 am »
I changed the resolution to 60 and the flashing frequency changed but still persisted. I tried 50 and everything came perfect.
In short, thanks for putting me on the right track Mark.  ;)
markrvp
  • NFL Expert
« Reply #5 on: January 05, 2006, 09:46:28 pm »
Cool.  I'm glad you got it fixed.
